1. Re: AME CS4 Hangs, Extremely Slow
Bill Hunt Jun 2, 2011 8:06 AM (in response to Brittanyls)Brittany,
WMV's take a lot of processing. If possible, you might want to consider converting those files, prior to Import. Things will be sped up greatly.
Now, that would address the "extremely slow" aspect, but might/might not address the hanging of AME.
As a test, I would ignore the Project and PrPro for a moment, and launch AME as a stand-alone app. Import one of the WMV's, unedited, and try to Export to your HD YouTube setting. Does AME complete that task?
I also do not see other details of your complete I/O Sub-system, i.e. your HDD's, other than Page File size and location, and system = C:\. Can you post the full details, with the HDD sizes, speed, amount of free space, controller type(s) and how you have your HDD's allocated for PrPro and AME? Also, do your have any partitioned HDD's?
2. Re: AME CS4 Hangs, Extremely Slow
John T Smith Jun 2, 2011 8:53 AM (in response to Brittanyls)>Everything is stored on my C:/ drive
Well... that is not good... you need at least two hard drives (separate drives, never a partition) with OS and software on your boot drive and video files on the 2nd drive
My 3 hard drives are configured as... (WD = Western Digital)
1 - 320G WD Win7 64bit Pro and all program installs
2 - 320G WD Win7 swap file and video project files
3 - 1T WD all video files... input & write files
Search Microsoft to find out how to redirect your Windows swap file
http://search.microsoft.com/search.aspx?mkt=en-US&setlang=en-US
Trying to use only ONE Hard Drive for Video Editing
You are a music conductor, with a baton that you use to point to various parts of the orchestra... this is like Windows pointing to various parts of the hard drive to do Windows housekeeping or to load program segments for various functions
Now, at the same time and with the same hand... while still using the baton to conduct the orchestra... pick up a bow and play a fiddle... this would be doing something with your video file at the same time as all the other work
You as a person cannot do both at the same time with the same hand
A computer is a LITTLE better, in that it can switch from one kind of task to another very quickly... but not quickly enough for easy video editing
You need AT LEAST two hard drives (separate drives, never a partition) with Windows (or Mac OS) and software on your boot drive, and video files on a 2nd drive so the boot drive is now slowed down by trying to do everything
I find that the three drives I use works very well for me, for editing AVCHD video
Depending on your exact hardware (motherboard brand & model AND USB2 enclosure brand & model AND hard drive brand & model) AND the type of video file, you may... or may NOT... be able to use an external USB2 hard drive for video editing
Steve Grisetti in the Premiere Elements forum http://forums.adobe.com/thread/856208?tstart=0 and Jim Simon in the Premiere Pro forum http://forums.adobe.com/thread/856433?tstart=0 use USB externals for editing
A USB3 hard drive connected to a motherboard with USB3 is supposed to be fast enough for video editing (I don't have such, so don't know) but eSata DOES have a fast enough data transfer for video editing... I have not used this eSata Dock... for reference only, YMMV and all the usual disclaimers
http://www.amazon.com/Thermaltake-BlacX-eSATA-Docking-Station/dp/B001A4HAFS/ref=cm_cmu_pg_ t -
3. Re: AME CS4 Hangs, Extremely Slow
Brittanyls Jun 2, 2011 10:03 AM (in response to John T Smith)function(){return A.apply(null,[this].concat($A(arguments)))}
Well... that is not good... you need at least two hard drives (separate drives, never a partition) with OS and software on your boot drive and video files on the 2nd drive would be doing something with your video file at the same time as all the other work
Unfortunately, purchasing extra drives is not something that is realistic financially for me right now. (Everytime I ask a question on here, someone always scolds me about my setup...)
Bill, I will test your suggestion and post that information for you as soon as I get home. I am assuming that I just didn't paste all of dxdiag?
4. Re: AME CS4 Hangs, Extremely Slow
Bill Hunt Jun 2, 2011 11:19 AM (in response to Brittanyls)(Everytime I ask a question on here, someone always scolds me about my setup...)
Brittany,
Don't think of it as "scolding," but instead just pointing out that a single HDD is sub-optimal for video editing, as it WILL be a bottleneck. Semantics? Yes, but in a very helpful way.
Good luck, and hope that John T's links will be helpful.
5. Re: AME CS4 Hangs, Extremely Slow
Brittanyls Jun 2, 2011 8:38 PM (in response to Bill Hunt)the_wine_snob wrote:
Brittany,
Well, I already do convert my files. Originally, the files are in .MTS format. I use Free HD Converter to convert them all to "WMV HD." I tried taking a small section of a sequence, and replacing all of the clips with AVIs created using the Free HD Converter. However, when put in Premiere, only a still image shows up with the sound playing in the background. Is there a format you would reccommend for using with Premiere?
Yes, AME completes that task quickly and without a problem.
I'm not sure if this is what you're looking for, but here it goes:
Everything is on my C:/ drive. It is not partitioned. I have 142 GB left of 581 GB. Everything saves to the default location of My Documents. I'm not sure if this is what you are looking for.
ALSO in my project there are many titles and a few MP4 videos. The MP4s were rendered in After Effects. I can't believe I forgot to include that in my original post...
So, I took an extremely small portion of the sequence, only about a minute long. This part consisted of only about 10 WMVs. The video would quickly load in AME and begin to encode. However, about 60% of the way through, AME would encounter an "Unknown Error." So, I'm assuming the problem is not with AME, but with my project itself.
-Brittany
6. Re: AME CS4 Hangs, Extremely Slow
Bill Hunt Jun 3, 2011 7:43 AM (in response to Brittanyls)Well, I already do convert my files. Originally, the files are in .MTS format. I use Free HD Converter to convert them all to "WMV HD." I tried taking a small section of a sequence, and replacing all of the clips with AVIs created using the Free HD Converter. However, when put in Premiere, only a still image shows up with the sound playing in the background. Is there a format you would reccommend for using with Premiere?
I see. I am not familiar with that conversion program, but WMV will not be your best intermediate format. You are starting with pretty heavily-compressed MPEG material, and then re-compressing to another format/CODEC, that requires a lot of processing power.
Have you tried just renaming one of the MTS files to .MPEG, and Importing that? Do one, as a test please, as that might get you a file that you can use, without any conversion.
7. Re: AME CS4 Hangs, Extremely Slow
Brittanyls Jun 3, 2011 12:57 PM (in response to Bill Hunt)Have you tried just renaming one of the MTS files to .MPEG, and Importing that? Do one, as a test please, as that might get you a file that you can use, without any conversion.
I can import the MTS files, but the problem is that in Premiere the videos skip, jump, and turn green. So, I have thought converting them to WMV would work, but I guess not.
Here is what happens when I change the name to .MPEG:
Premiere still recognizes the video as MTS format, so the video still skips. Here are my other options for conversion with the HD converter:
I have already tried converting the video to Avi (High quality), but when imported the sound plays correctly and the video is a still image. SHould I try MPEG2 HD? Or use a different converter?
EDIT: I don't know if this program is reliable. I just tried converting an MTS video into MPEG2 HD format, and when imported into Premiere, the sound was absolutely horrible. Is there a *free* HD video converter that anyone can reccommend, and a format?
