3 Replies Latest reply on Jun 2, 2011 1:32 PM by adninjastrator
    set path to flv in flash...
    r_tist Level 1
      I cannot recall where I go to specify the path direct to the FLV file from within Flash after placing the PlayBack component / skin over the movie on the stage.
      Can you advise? If I remember correctly, this is the last step before publishing the movie (in order to have embedded in an HTML page)?
      Many thanks!
        • 2. Re: set path to flv in flash...
          r_tist Level 1
          Thanks - Is it best to keep the link absolute? I always seem to have difficulty getting it to play. And I've got everything in the same folder as well.
          • 3. Re: set path to flv in flash...
            adninjastrator Level 4
            No it's not necessary to use absolute addresses as long as you understand that paths to the Flash assets need to be relative to the Web page, NOT the actual location of the .swf or the .flv. In fact, keeping everything "in the same folder" can be counter-intuative, unless "everything" includes the Web page.
            So a .swf playing an flv file, both which are in the same folder (but NOT the same folder as the Web page) will play just fine... till you place that .swf on a Web page outside that folder. In fact, a correctly pathed .swf video player located in the SAME folder as the .flv video file (but NOT the same folder as the Web page), should NOT work when you test the .swf directly! It should be pathed to locate the .flv file from the Web page, not the actual location of the .swf.
            For review:
            Pathing issues
            Almost always when it works on the local machine and not the server, it's a pathing problem.
            You can put your Flash related files in whatever folders you want, they do NOT have to be in the root, they do NOT all have to be in the same folder. But if you have a problem and if sticking them all in the root folder works, then you know that the issue was a pathing problem.
            Just remember that paths used in the .swf become relative to the Web page on which the .swf is placed, NOT it’s physical location.  So for example, if your .swf is in the flash/data folder and you use that .swf on a Web page in the root folder, you are in effect, removing that .swf from flash/data and putting it in root. So if the .swf is loading any related files (xml, images, video, etc), the path used inside the .swf to load the .xml file has to be relative to it's new location in root and then back down into flash/data. This is true even though when testing the .swf by itself, it can be inside flash/data and work just fine, since relative to it's location, the path is just fine, they are in the same folder. But if that same path is used when the .swf is placed on a page two folder levels up, the relative path has changed, the old "same folder" path will not work.
            In fact if you are placing the .swf on a web page in a different folder than the .swf is stored in, and that .swf calls external assets, then direct clicking and opening of the .swf in it’s folder should NOT work! That’s because the paths to the external assets should be relative to the Web page and not the physical location of the .swf.
            So just be sure that you use addresses relative to the final Web page locations (not physical file locations) and you can put the Flash related files in what ever folders you want.
            Best wishes,
            Eye for Video
            www.cidigitalmedia.com
            Best wishes,
            Adninjastrator
