6 Replies Latest reply on Jun 7, 2011 11:17 PM by Anirudh Sasikumar
    Using Export Release Build removes folders and doesn't generate an .apk file
    wtfaremypants
      I'm using FB4.5 on a PC. Here's what I'm trying to do:
      I have a simple Actionscript Mobile project that I have completed debugging with no problems. Now I need to export my release build to get my .apk file for the Android Market.
      When I go through all the steps of Export Release Build, FB builds the set, then seems to delete the /bin-release folder containing all the files it just created and I get no .apk file anywhere.
      The only reason I know the files are being created in the first place, is that I watched the folder in explorer as soon as it was created. Any thoughts? Is there a better way to do this? I know there are command line tools to do the packaging, but it seems like all I need is right in FB4.5, it just doesn't work quite properly?
        • 1. Re: Using Export Release Build removes folders and doesn't generate an .apk file
          wtfaremypants Level 1
          Is nobody else packaging for Android on FB4.5? Bump.
          • 2. Re: Using Export Release Build removes folders and doesn't generate an .apk file
            After much more testing, I can see now that the Export Release Build always deletes the /bin-release folder when it is complete. IMHO this is a bug, since you have no opportunity to edit the X-app.xml build file before it gets incorporated into the .apk unless you cancel the build process before its complete, edit the app.xml and then restart the Export Release Build process.
            • 3. Re: Using Export Release Build removes folders and doesn't generate an .apk file
              Anirudh Sasikumar Adobe Employee
              bin-release is a temporary folder used prior to packaging. Removal of bin-release is expected behavior (though I understand that this does not play well with you wanting to edit app.xml).
              Can you post the contents of your Flash Builder log file here? (workspacedir/.metadata/.log; workspacedir by default is c:\users\xxx\Adobe Flash Builder 4.5)
              -Anirudh
              • 4. Re: Using Export Release Build removes folders and doesn't generate an .apk file
                !SESSION 2011-05-03 20:41:52.851 -----------------------------------------------
                eclipse.buildId=unknown
                java.version=1.6.0_16
                java.vendor=Sun Microsystems Inc.
                BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
                Command-line arguments:  -os win32 -ws win32 -arch x86
                This is a continuation of log file C:\Users\TB\Desktop\Development\~Projects\flash\.metadata\.bak_0.log
                Created Time: 2011-05-04 08:53:22.543
                !ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.543
                !MESSAGE Unhandled event loop exception during blocked modal context.
                !STACK 0
                org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Graphic is disposed)
                    at org.eclipse.swt.SWT.error(SWT.java:3884)
                    at org.eclipse.swt.SWT.error(SWT.java:3799)
                    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:137)
                    at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3855)
                    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3476)
                    at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:173)
                    at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:388)
                    at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
                    at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog. java:275)
                    at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.disconnectFromWorkspace(IDEWo rkbenchAdvisor.java:460)
                    at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.postShutdown(IDEWorkbenchAdvi sor.java:316)
                    at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:2732)
                    at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:939)
                    at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:856)
                    at org.eclipse.ui.internal.Workbench$23.run(Workbench.java:1100)
                    at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
                    at org.eclipse.ui.internal.Workbench.close(Workbench.java:1098)
                    at org.eclipse.ui.internal.Workbench.close(Workbench.java:1070)
                    at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:721)
                    at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:700)
                    at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindow.java:816)
                    at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:814)
                    at org.eclipse.jface.window.Window.handleShellCloseEvent(Window.java:741)
                    at org.eclipse.jface.window.Window$3.shellClosed(Window.java:687)
                    at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:92)
                    at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
                    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
                    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
                    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
                    at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations.java:308)
                    at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.java:1645)
                    at org.eclipse.swt.widgets.Control.windowProc(Control.java:3948)
                    at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:342)
                    at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1578)
                    at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2010)
                    at org.eclipse.swt.widgets.Display.windowProc(Display.java:4589)
                    at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
                    at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2405)
                    at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:492)
                    at org.eclipse.swt.widgets.Control.windowProc(Control.java:4036)
                    at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
                    at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2410)
                    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3471)
                    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
                    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
                    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
                    at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
                    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
                    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
                    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
                    at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java :109)
                    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
                    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
                    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                    at java.lang.reflect.Method.invoke(Unknown Source)
                    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
                    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
                    at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
                Caused by: org.eclipse.swt.SWTException: Graphic is disposed
                    at org.eclipse.swt.SWT.error(SWT.java:3770)
                    at org.eclipse.swt.graphics.Image.getImageData(Image.java:1199)
                    at org.eclipse.jface.resource.ImageDataImageDescriptor.<init>(ImageDataImageDescriptor.java: 36)
                    at org.eclipse.jface.resource.ImageDescriptor.createFromImage(ImageDescriptor.java:104)
                    at com.adobe.flexide.editorcore.ui.FlexImageDatabase.getOverlayImage(FlexImageDatabase.java: 251)
                    at com.adobe.flexide.editorcore.ui.SharedImages.getProblemDecoratedImage(SharedImages.java:1 69)
                    at com.adobe.flexide.editorcore.editor.AbstractFlexEditor$6.run(AbstractFlexEditor.java:1454 )
                    at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
                    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
                    ... 73 more
                    ... 73 more
                !ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.555
                !STACK 0
                    ... 73 more
                !ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.556
                !STACK 0
                    ... 73 more
                !ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.557
                !STACK 0
                    ... 73 more
                !ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.558
                !STACK 0
                    ... 73 more
                !ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.559
                !STACK 0
                    ... 73 more
                !ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.560
                !STACK 0
                    ... 73 more
                !ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.561
                !STACK 0
                    ... 73 more
                • 5. Re: Using Export Release Build removes folders and doesn't generate an .apk file
                  Also note that if this is expected behavior, then why does the bin-release folder NOT get removed when I package a
                  regular Actionscript project? I've only see this happen with the Actionscript Mobile project for Android/AIR.
                  • 6. Re: Using Export Release Build removes folders and doesn't generate an .apk file
                    > why does the bin-release folder NOT get removed when I package a regular Actionscript project?
                    If you create an ActionScript AIR project, bin-release does get removed (it did for me, I just tried it).
                    If you create a web project, then bin-release stays.
                    In your case, if bin-release did not get cleaned up, *that* is unexpected.
                    Getting back to your problem, your log file only showed errors when shutting down Eclipse. Nothing to do with Export release. I have two more things for you to try out:
                    * Create a totally new mobile project, copy the sources over and try an export release build.
                    * If that also fails, try packaging your mobile project as a "Signed AIR package" and see if that works.
                    If the above steps don't help, email your project over and I'll take a look.
                    -Anirudh
                    Computer Scientist,
                    Flash Builder Engineering
