7 Replies Latest reply on Oct 14, 2011 4:14 AM by sandeepgeorge
    Export Release Build error
    Zolotoj Level 3
      I am exporting AIR project and getting the following error after providing a certificate:
      "Error occurred while saving the project settings: "default" build target cannot be found for the selected project."
      I am using FB 4.5.
        • 1. Re: Export Release Build error
          Zolotoj Level 3
          Anyone, any clue?
          • 2. Re: Export Release Build error
            ALF-35-MSAP
            workaround:
            0) In a new workspace
            1) Create again with FB45 new Flex project - Application type Dekstop (runs in Adobe AIR)
            2) copy paste src *.as & css from other workspace/project (eg FB4.0)
            3) replace content of empty mxml by old one.
            4) export release build (Signed AIR package)
            Note : for me ok only without timestamp (connection timed out issue)
            • 3. Re: Export Release Build error
              Zolotoj Level 3
              Can the problem be because in my AIR project I am using an external SWC which is my common libaray.
              • 4. Re: Export Release Build error
                ALF-35-MSAP Level 1
                May be ?
                In addition to this new project with the new .mxml and the old .css and .as that give me the .air
                I have also an other project with my .swc, this project have been imported from FB40 to FB45.
                • 5. Re: Export Release Build error
                  DaveCates Level 1
                  I got this error too using FB4.5
                  My project was originally setup to take an import from Catalyst. I then converted it to Air when I needed to include the File libraries.
                  The way I got around this issue was to create a whole new FB project aimed at Air. Then I copied over all my files from the previous project.
                  Worked perfectly then.
                  I wonder if this is a bug related to Catalyst and/or the conversion of a project to Air?
                  Really hope we have the conversion working the other way soon - Air back to Swf. AND...why aren't Air projects compatible with Catalyst yet?
                  Probably early days but, can't wait
                  Hope this helps someone else.
                  • 6. Re: Export Release Build error
                    Jason Woodcock Level 1
                    I get this error as well everytime I create a mobile project in the lastest version of Launchpad, import the resulting files into Flex Builder 4.5 then try to export the project as a signed AIR desktop app. Exporting Release Build to a mobile target device works fine however.
                    Here is my log file as well:
                    !ENTRY com.adobe.flexbuilder.project 4 43 2011-09-09 17:33:29.640
                    !MESSAGE Failed to get build target settings: default
                    !STACK 0
                    java.lang.Exception
                         at com.adobe.flexbuilder.project.internal.FlexProjectCore.createErrorStatus(FlexProjectCore. java:1009)
                         at com.adobe.flexbuilder.util.logging.GlobalLogImpl.log(GlobalLogImpl.java:66)
                         at com.adobe.flexbuilder.util.logging.GlobalLog.log(GlobalLog.java:52)
                         at com.adobe.flexbuilder.project.ui.utils.ProjectBuildPackagingUI.doApplySettings(ProjectBui ldPackagingUI.java:754)
                         at com.adobe.flexbuilder.project.ui.utils.ProjectBuildPackagingUI.applySettings(ProjectBuild PackagingUI.java:781)
                         at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionBuildPackagingPa geContent.saveSettings(ExportReleaseVersionBuildPackagingPageContent.java:131)
                         at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionBuildPackagingPa ge.saveSettings(ExportReleaseVersionBuildPackagingPage.java:84)
                         at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard.performFi nish(ExportReleaseVersionWizard.java:144)
                         at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
                         at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
                         at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
                         at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
                         at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
                         at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
                         at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
                         at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
                         at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
                         at org.eclipse.jface.window.Window.open(Window.java:801)
                         at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction$1.run(Export ReleaseVersionAction.java:97)
                         at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction.run(ExportRe leaseVersionAction.java:103)
                         at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
                         at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
                         at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:584)
                         at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
                         at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :411)
                         at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
                         at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
                         at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
                         at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
                         at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
                         at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
                         at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
                         at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.ja va:108)
                         at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
                         at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                         at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                         at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
                         at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                         at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                         at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                         at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                         at java.lang.reflect.Method.invoke(Unknown Source)
                         at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
                         at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
                         at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
                    Update:
                         As a work around, I tried to export it as an unsigned airi, then manually signed it with ADT using a self signed certificate and it worked perfectly...
                    Message was edited by: Jason Woodcock
