1 Reply Latest reply on Jun 2, 2011 10:20 PM by kenji776
    Google Docs Upload
    kenji776 Level 1
      Hey all,
      I am working off the google API put together by Ray Camden to allow interactions with google docs. I am attempting to build a function to upload documents, but I am not quite sure how to put together the HTTP request. I just keep getting rejected no matter what I do. I've tried having the file content as a form field param and in the body of the request, both get rejected.
      The docs for uploading are here
      http://code.google.com/apis/documents/docs/2.0/developers_guide_protocol.html#UploadingDoc s
      This is my function as it stands. I keep getting bad request errors (error 400)
      <cffunction name="upload" access="public" returnType="any" hint="I upload the document." output="false">
          <cfargument name="myFile" type="string" required="false" hint="file to upload.">
          <cfset var result = "">
          <cfset theUrl = "https://docs.google.com/feeds/documents/private/full HTTP/1.1">
          <cffile action="read" file="C:\website\xerointeractive\testing\test.txt" variable="theFile">
          <cfset fileSize = createObject("java","java.io.File").init("C:\website\xerointeractive\testing\test.txt").length()>
          <cfhttp url="#theURL#" method="post" result="result" charset="utf-8" >
              <cfhttpparam type="header" name="Authorization" value="GoogleLogin auth=#getAuth()#">
              <cfhttpparam type="header" name="Content-Type" value="text/plain">
              <cfhttpparam type="header" name="Slug" value="test file">
              <cfhttpparam type="header" name="Content-Length" value="#fileSize#">
              <cfhttpparam type="body" name="file" value="#theFile#">
          </cfhttp>
          <cfreturn result>
      </cffunction>
      You can see a what it is doing here
      http://xerointeractive.com/testing/docstest.cfm
      (may change as I am working on it)
      I also built a page to print out the headers and data sent to it on request, and pointed my uploader to it. These are the results I got.
      http://i.imgur.com/ykk7H.png
      All in all the request looks good to me. I'm not real sure what I'm doing wrong. Any insight would be useful. Thanks!
        • 1. Re: Google Docs Upload
          kenji776 Level 1
          Woot, I got it. I had to send the gData version number, and change the URL.
          Here is the working function.
              <cfset theUrl = "https://docs.google.com/feeds/default/private/full">
                  <cfhttpparam type="header" name="GData-Version" value="3">
                  <cfhttpparam type="body" value="#theFile#">
              </cfhttp>
              <cfreturn result>
          </cffunction>
