4 Replies Latest reply on Jun 3, 2011 5:19 AM by SunilRana_Gateway
    import image with 72 DPI in adode AIR application? which will not reduce quality of image?
    SunilRana_Gateway
      impoart image with 72 DPI in adode AIR application?  right now in Windows applicaion, i am importing image with 96 DPI.
      In Our Application,we want that image which we will importing, it  won't  be low quality.It will be best Quality image.How can we achive this in our Application.
      Please suggest some solution which will be great for me
      Sunil
        • 1. Re: import image with 72 DPI in adode AIR application? which will not reduce quality of image?
          aktell2007
          Hi there,
          **** DPI (dots per inch) is a measurement of printer resolution,  though it is commonly applied, somewhat inappropriately, to monitors,  scanners and even digital cameras.
          For printers, the DPI  specification indicates the number of dots per inch that the printer is  capable of achieving to form text or graphics on the printed page. The  higher the DPI, the more refined the text or image will appear. To save  ink, a low DPI is often used for draft copies or routine paperwork.  This setting might be 300 or even 150 DPI. High resolution starts at  600 DPI for standard printers, and can far exceed that for color  printers designed for turning out digital photography or other  high-resolution images. ****
          So, please ask the question again, and say what the resolution of your Images could be 380 kB for example, and what do you call best quality of an Image ???
          regards aktell
          • 2. Re: import image with 72 DPI in adode AIR application? which will not reduce quality of image?
            pauland Level 4
            Sunil, DPI isn't really relevant. Your display is sized in pixels and your images are best supplied in the same resolution (regardless of DPI setting) that you wish to use them.
            Paul
            • 3. Re: import image with 72 DPI in adode AIR application? which will not reduce quality of image?
              SunilRana_Gateway Level 1
              Hi Paul and aktell,
                       My application having import image for use in Photo Album so when we import file in Adobe AIR application
                         we had code for create three folder 1) Low Resolution - This folder image used in Thumbnail view(imaze size 300 X 150)
                          2) Mid Resolution - This folder image used in slideshow and it's image size is 1000 X 600
                          3)High Resolution - This folder image used in report generation  and its image size is original as user import from original source.
                   My  main issue is make only one folder which having best quality image ,without pixalated when we used in big container which having 1200 X1200 size and showing image with best quality and also it will not big size so if user import 500 hunderd images which cannot degrade performance of application.
              Sunil
              • 4. Re: import image with 72 DPI in adode AIR application? which will not reduce quality of image?
                pauland Level 4
                If you don't want' performance slowdown, only load the large images when necessary. Use the server side to process larger images to create thumbnails and intermediate sizes from the larger images.
                If all the images are static, you can batch process them using Photoshop or a similar application.
