6 Replies Latest reply on Jun 3, 2011 6:29 AM by deyan none
    MX and Spark Labels get wider than parent container
    deyan none Level 1
      Hi there,
      Labels in flex have pretty odd behaviour when dealing with long text. Here is an example:
                     xmlns:mx="library://ns.adobe.com/flex/mx"
                     minWidth="955" minHeight="600">
          <fx:Script>
              <![CDATA[
                  [Bindable]
                  private var text : String;
                  private function setText() : void {
                      text = "XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX XXX";
                      label2.text = "Label 1 width: " + label.width;
          </fx:Script>
          <s:Panel width="200" >
              <s:VGroup>
                  <mx:Label id="label" text="{text}" truncateToFit="true" />
                  <s:Button click="setText()" label="Set text" />
                  <mx:Label id="label2" />
              </s:VGroup>
          </s:Panel>
      </s:Application>
      My beliefs are that the label should not be wider than its parent container - which is 200 px.
      In this case the truncateToFit parameter plays no role at all !
      Is this a bug or a feature ? It works for both MX and Spark labels
        • 1. Re: MX and Spark Labels get wider than parent container
          _spoboyle Level 4
          parent containers resize to fit their children set the labels width to 100% (or perhaps maxWidth to 100% I haven't tried this)
          • 2. Re: MX and Spark Labels get wider than parent container
            deyan none Level 1
            Actually no.
            As seen on the screenshot in my post - the parent container ( a Panel ) does not resize. The label goes out of its container.
            Also maxWidth can not be set to a percentage value , it accepts only numbers.
            • 3. Re: MX and Spark Labels get wider than parent container
              _spoboyle Level 4
              this works for me using spark labels
                   <fx:Script>
                        <![CDATA[
                             [Bindable]
                   </fx:Script>
                        <s:VGroup width="100%">
                             <s:Label id="label" text="{text}" maxDisplayedLines="1" width="100%"/>
                             <s:Label id="label2" />
                        </s:VGroup>
                   </s:Panel>
              • 4. Re: MX and Spark Labels get wider than parent container
                deyan none Level 1
                Yes, spark label seems to work.
                Now if there was an easy way to make it selectable ...
                10x for the hint
                • 5. Re: MX and Spark Labels get wider than parent container
                  _spoboyle Level 4
                  You cannot make a Label selectable without subclassing it
                  Flex docs suggest using RichEditableText (however this cannot be truncated with the ...)
                  I have this solution which simply restricts the RichEditableText to 1 line without ...
                       <fx:Script>
                            <![CDATA[
                                 [Bindable]
                       </fx:Script>
                                 <s:RichEditableText id="label" text="{text}" width="100%" heightInLines="1" editable="false" selectable="true"/>
                            </s:VGroup>
                       </s:Panel>
                  if that's not good enough you can use this subclass of TextInput in place of the RichEditableText
                  http://sharathchandra.wordpress.com/2010/12/23/truncated-textinput-flex-4/
                  which will allow selection like i have above with the trunaction
                  • 6. Re: MX and Spark Labels get wider than parent container
                    deyan none Level 1
                    Yes, RichEditableText was also my best guess
                    Another option was spark TextArea, editable=false and contentBackgroundAlpha=0 .
                    10x for the help
