2 Replies Latest reply on Jun 3, 2011 6:58 AM by the_wine_snob
    PE8 DVD CREATION
    STILLERULE
      When I try to burn a DVD using Elements 8 it gets almost completely done and then my computer recognizes that it has a new dvd, tries to open it and elements shuts down the final steps of burning the dvd.  Any suggestions?  Thanks!
        • 1. Re: PE8 DVD CREATION
          This likely indicates that the program is completing its DVD transcoding, but is having trouble interfacing with the DVD burner.
          This can happen if you're running Windows 7 64-bit, or it can happen if you have a program like Nero installed (which has a tendency to monopolize your burner).
          In either event, the best test is to see if you can burn your DVD files to a folder on your hard drive.
          If it works, you know it's a problem with the DVD burner. If not, then we'll need to dig deeper into your system with a series of troubleshooting steps.
          • 2. Re: PE8 DVD CREATION
            the_wine_snob Level 9
            Along with Steve's suggestion to test by doing a Burn to Folder, take a look at this ARTICLE for some possibilities, regarding your burner/multi-drive.
