2 Replies Latest reply on Nov 27, 2006 2:48 PM by brianraymes
    Memory release?
    jotster
      Whats the prefered way to post code here?
      Im having trouble with memory release I think... the scenario is that a button should toggle an titlewindow on and off. The titlewindow in itself handles some timed remoting (fetch XML documents at an interval) and I dont want to have it running in the background when its not displayed.
      Code follows
      public var helpWindow:IFlexDisplayObject;
      private function showHelp():void {
      // Create a non-modal TitleWindow container.
      if(helpWindow==null) {
      helpWindow = PopUpManager.createPopUp(this, wdwHelp, false);
      } else {
      PopUpManager.removePopUp(helpWindow);
      helpWindow=null;
      When nulling helpWindow, shouldnt memory be released? Because on repeated presses of the "toggle" button I can see that memory usage increases constantly.
        • 1. Re: Memory release?
          inlineblue Level 1
          Note that the Flash Player uses a garbage collector for memory management. Memory is released only when the garbage collector runs, and you have no control as to when that happens.
          • 2. Re: Memory release?
            brianraymes
            quote:
            There is no possible way to force, or activate the garbage collector? Does it only run when it decides the system is low on memory? I have an application that is increasing 5 mbs per click (loads a project with a bunch of pictures). I null everything/clearResults/etc as a new project is selected, but it just keeps growing and growing... Help?
