1 Reply Latest reply on Mar 23, 2009 10:48 AM by Rothrock
    Error message Flash 8 and line spacing
    ldlouis
      Hi all
      I'm using Flash 8 and I was saving the swf file in version Flash 7 because
      I was having trouble with line spacing with version 8.
      In "Version 7" I get this exactly what I want
      [IMG]http://www3.sympatico.ca/ralix/imgs/pic2.jpg[/IMG]
      in "Version 8" I get this
      [IMG]http://www3.sympatico.ca/ralix/imgs/pic1.jpg[/IMG]
      Now I'm getting this error message in Version 7
      [QUOTE]**Error** C:\Users\LD\AppData\Local\Macromedia\Flash
      8\en\Configuration\Classes\FP8\MovieClip.as: Line 36: The class or interface
      'flash.geom.Rectangle' could not be loaded.
      var scale9Grid:Rectangle;
      8\en\Configuration\Classes\FP8\MovieClip.as: Line 51: The class or interface
      'flash.geom.Transform' could not be loaded.
      var transform:Transform;
      8\en\Configuration\Classes\FP8\MovieClip.as: Line 55: The class or interface
      'flash.display.BitmapData' could not be loaded.
      function attachBitmap(bmp:BitmapData, depth:Number,
      pixelSnapping:String, smoothing:Boolean):Void;
      8\en\Configuration\Classes\FP8\MovieClip.as: Line 59: The class or interface
      function beginBitmapFill(bmp:BitmapData, matrix:Matrix,
      repeat:Boolean, smoothing:Boolean):Void;
      Total ActionScript Errors: 4 Reported Errors: 4[/QUOTE]
      thank you for the help
        • 1. Re: Error message Flash 8 and line spacing
          Rothrock Level 5
          Well the flash.geom.* package and BitmapData aren't available in Flash 7. So you will have much bigger problems than line spacing if you try and publish to Flash 7.
          I have no idea about the spacing but that is going to be possible to fix. The errors you are getting are not possible to fix in Flash 7.
