10 Replies Latest reply on Jun 6, 2011 8:14 AM by tomnahas
    Rendering Quits at 1GB - HELP!!!
    tomnahas
      I am rendering my 43 min short film to preview with an H.264 MP4 720P. It predicts that the file is going to be 1.5GB. It seems that it keeps quitting when the file reaches 1 GB. The are some dynamically linked comps from AE as well.
      I have CS5 Master on a Dell XPS, 12GB RAM and quadro 4000 video card.
      Any ideas why this would be happening?
        • 1. Re: Rendering Quits at 1GB - HELP!!!
          the_wine_snob Level 9
          Welcome to the forum.
          Quitting at a certain file size could be a lack of HDD space on the destination disc. If possible, let's rule that out quickly. How much defragmented free space to you have on the destination disc, and also on the HDD, where your Scratch Disks are located?
          • 2. Re: Rendering Quits at 1GB - HELP!!!
            tomnahas Level 1
            Space shoulndt be an issue. I have about 250 Gb on the drive i am rendering to. All of my src files are on an external.  I do have the scratch disks set to the D drive that i am rendering to...could that be the problem? Should i set those to my C drive?
            Sent from my iPod
            • 3. Re: Rendering Quits at 1GB - HELP!!!
              Jim_Simon Level 8
              Another quick check.  Is the drive formatted as NTFS?
              • 4. Re: Rendering Quits at 1GB - HELP!!!
                With a FAT-32 HDD, one should be able to get ~ 4GB, rather than the 1GB file size reported.
                • 5. Re: Rendering Quits at 1GB - HELP!!!
                  tomnahas Level 1
                  I am pretty sure it is NTFS. It was a factory
                  installed secondary drive on a PC.....
                  I was able to render out a 720x480 H.264 mp4 which
                  came in around 600MB.
                  And I am certain that i rendered a video for work
                  that was 1.2GB in the past.
                  Thanks for your help guys....
                  I have tried it as a direct export from Premiere,
                  export from Media Encoder and also when dynamically
                  linking to Encore. In the case of Encore it failed
                  during encoding so i am assuming it is the same
                  issue.
                  Original message -
                    Date: Sat, 04 Jun 2011 16:29:36 -0600
                    Subject: Rendering
                    To: Tom Nahas <nahast@oakgov.com>
                    >With a FAT-32 HDD, one should be able to get ~
                    >Hunt
                  • 6. Re: Rendering Quits at 1GB - HELP!!!
                    Out of curiosity, what is on your Timeline at about the 2/3 point? Is that about where you have the AE Comps (just a suspicion on my part), or is there some other Asset there? I'd poke around that general point in the Timeline, to see if you have a gap in the Video, a dodgey Asset, or something out of the ordinary.
                    Often, when Encoding/Transcoding fails, one gets an error message, that though a bit cryptic, can offer some hints. Other times, the process just fails. As you did not mention any error messages, I assume that the process just failed.
                    You might also want to set the WAB (Work Area Bar) to before that point, and test an Export. If that works, then reset the WAB to arouond that 2/3 point, and test Export again. It might take a few tries, but perhaps you can narrow things down to an exact place on the Timeline.
                    • 7. Re: Rendering Quits at 1GB - HELP!!!
                      tomnahas Level 1
                      Bill - I was thinking that too....There is an AE comp at that point. I rendered just that section and it was fine. I even replaced that AE comp with a rendered clip and that worked as well.
                      I will keep trying.
                      • 8. Re: Rendering Quits at 1GB - HELP!!!
                        ADL (Adobe Dynamic Link) normally works just fine - but sometimes things do go wonky. I understand the desire to use ADL for the AE Comps, but if replacing the linked Comp with an Exported one works, that might be far easier, than fighting the ADL issue at that point.
                        As my use of AE and ADL are on a rather limited basis, others might have great tips for troubleshooting the linked Comp(s). At my level, I'd be more inclined to just redo things, as I would not likely be able to see where the issues could be. Todd is our "resident AE" expert here, but others know the ins and outs of ADL to AE, so will be far better suited to help there, than I am.
                        • 9. Re: Rendering Quits at 1GB - HELP!!!
                          anuraggrwl Level 2
                          Can you please switch from MPE GPU accelerated to Software only and then try rendering...
                          We have seen similar issues if it works please update your drivers for Quadro 4000...
                          • 10. Re: Rendering Quits at 1GB - HELP!!!
                            tomnahas Level 1
                            Thanks, I will try that.
