3 Replies Latest reply: Jun 4, 2011 9:37 AM by 370H55V RSS
    Centering  a webpage on all browers using html
    WebGuyDesign Community Member
      hi, I am trying to center this webpage so that it remains in the center no matter the size of the brower but there are always a black space on the right of the page, can someone give me a hand with the code.
      <head>
        <link rel="SHORTCUT ICON" href="http://www.bobbypic.com/shortcut.ico"/>
        <title>demo page</title>
      </head>
      <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
      <title>bobbypic</title>
      <script language="JavaScript" type="text/javascript">
      //v1.7
      // Flash Player Version Detection
      // Detect Client Browser type
      // Copyright 2005-2008 Adobe Systems Incorporated.  All rights reserved.
      var isIE  = (navigator.appVersion.indexOf("MSIE") != -1) ? true : false;
      var isWin = (navigator.appVersion.toLowerCase().indexOf("win") != -1) ? true : false;
      var isOpera = (navigator.userAgent.indexOf("Opera") != -1) ? true : false;
      function ControlVersion()
      var version;
      var axo;
      var e;
      // NOTE : new ActiveXObject(strFoo) throws an exception if strFoo isn't in the registry
      try {
        // version will be set for 7.X or greater players
        axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.7");
        version = axo.GetVariable("$version");
      } catch (e) {
      if (!version)
        try {
         // version will be set for 6.X players only
         axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.6");
         // installed player is some revision of 6.0
         // GetVariable("$version") crashes for versions 6.0.22 through 6.0.29,
         // so we have to be careful.
         // default to the first public version
         version = "WIN 6,0,21,0";
         // throws if AllowScripAccess does not exist (introduced in 6.0r47)
         axo.AllowScriptAccess = "always";
         // safe to call for 6.0r47 or greater
        } catch (e) {
      if (!version)
        try {
         // version will be set for 4.X or 5.X player
         axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.3");
        } catch (e) {
      if (!version)
        try {
         // version will be set for 3.X player
         version = "WIN 3,0,18,0";
        } catch (e) {
      if (!version)
        try {
         // version will be set for 2.X player
         axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash");
         version = "WIN 2,0,0,11";
        } catch (e) {
         version = -1;
      return version;
      // JavaScript helper required to detect Flash Player PlugIn version information
      function GetSwfVer(){
      // NS/Opera version >= 3 check for Flash plugin in plugin array
      var flashVer = -1;
      if (navigator.plugins != null && navigator.plugins.length > 0) {
        if (navigator.plugins["Shockwave Flash 2.0"] || navigator.plugins["Shockwave Flash"]) {
         var swVer2 = navigator.plugins["Shockwave Flash 2.0"] ? " 2.0" : "";
         var flashDescription = navigator.plugins["Shockwave Flash" + swVer2].description;
         var descArray = flashDescription.split(" ");
         var tempArrayMajor = descArray[2].split(".");
         var versionMajor = tempArrayMajor[0];
         var versionMinor = tempArrayMajor[1];
         var versionRevision = descArray[3];
         if (versionRevision == "") {
          versionRevision = descArray[4];
         if (versionRevision[0] == "d") {
          versionRevision = versionRevision.substring(1);
         } else if (versionRevision[0] == "r") {
          if (versionRevision.indexOf("d") > 0) {
           versionRevision = versionRevision.substring(0, versionRevision.indexOf("d"));
         var flashVer = versionMajor + "." + versionMinor + "." + versionRevision;
      // MSN/WebTV 2.6 supports Flash 4
      else if (navigator.userAgent.toLowerCase().indexOf("webtv/2.6") != -1) flashVer = 4;
      // WebTV 2.5 supports Flash 3
      else if (navigator.userAgent.toLowerCase().indexOf("webtv/2.5") != -1) flashVer = 3;
      // older WebTV supports Flash 2
      else if (navigator.userAgent.toLowerCase().indexOf("webtv") != -1) flashVer = 2;
      else if ( isIE && isWin && !isOpera ) {
        flashVer = ControlVersion();
      return flashVer;
      // When called with reqMajorVer, reqMinorVer, reqRevision returns true if that version or greater is available
      function DetectFlashVer(reqMajorVer, reqMinorVer, reqRevision)
      versionStr = GetSwfVer();
      if (versionStr == -1 ) {
        return false;
      } else if (versionStr != 0) {
        if(isIE && isWin && !isOpera) {
         // Given "WIN 2,0,0,11"
         tempArray         = versionStr.split(" ");  // ["WIN", "2,0,0,11"]
         tempString        = tempArray[1];   // "2,0,0,11"
         versionArray      = tempString.split(","); // ['2', '0', '0', '11']
        } else {
         versionArray      = versionStr.split(".");
        var versionMajor      = versionArray[0];
        var versionMinor      = versionArray[1];
        var versionRevision   = versionArray[2];
               // is the major.revision >= requested major.revision AND the minor version >= requested minor
        if (versionMajor > parseFloat(reqMajorVer)) {
         return true;
        } else if (versionMajor == parseFloat(reqMajorVer)) {
         if (versionMinor > parseFloat(reqMinorVer))
          return true;
         else if (versionMinor == parseFloat(reqMinorVer)) {
          if (versionRevision >= parseFloat(reqRevision))
           return true;
        return false;
      function AC_AddExtension(src, ext)
        if (src.indexOf('?') != -1)
          return src.replace(/\?/, ext+'?');
        else
          return src + ext;
      function AC_Generateobj(objAttrs, params, embedAttrs)
        var str = '';
        if (isIE && isWin && !isOpera)
          str += '<object ';
          for (var i in objAttrs)
            str += i + '="' + objAttrs[i] + '" ';
          str += '>';
          for (var i in params)
            str += '<param name="' + i + '" value="' + params[i] + '" /> ';
          str += '</object>';
        else
          str += '<embed ';
          for (var i in embedAttrs)
            str += i + '="' + embedAttrs[i] + '" ';
          str += '> </embed>';
        document.write(str);
      function AC_FL_RunContent(){
        var ret =
          AC_GetArgs
          (  arguments, ".swf", "movie", "clsid:d27cdb6e-ae6d-11cf-96b8-444553540000"
           , "application/x-shockwave-flash"
        AC_Generateobj(ret.objAttrs, ret.params, ret.embedAttrs);
      function AC_SW_RunContent(){
        var ret =
          AC_GetArgs
          (  arguments, ".dcr", "src", "clsid:166B1BCA-3F9C-11CF-8075-444553540000"
           , null
      function AC_GetArgs(args, ext, srcParamName, classid, mimeType){
        var ret = new Object();
        ret.embedAttrs = new Object();
        ret.params = new Object();
        ret.objAttrs = new Object();
        for (var i=0; i < args.length; i=i+2){
          var currArg = args[i].toLowerCase();
          switch (currArg){
            case "classid":
              break;
            case "pluginspage":
              ret.embedAttrs[args[i]] = args[i+1];
              break;
            case "src":
            case "movie":
              args[i+1] = AC_AddExtension(args[i+1], ext);
              ret.embedAttrs["src"] = args[i+1];
              ret.params[srcParamName] = args[i+1];
              break;
            case "onafterupdate":
            case "onbeforeupdate":
            case "onblur":
            case "oncellchange":
            case "onclick":
            case "ondblclick":
            case "ondrag":
            case "ondragend":
            case "ondragenter":
            case "ondragleave":
            case "ondragover":
            case "ondrop":
            case "onfinish":
            case "onfocus":
            case "onhelp":
            case "onmousedown":
            case "onmouseup":
            case "onmouseover":
            case "onmousemove":
            case "onmouseout":
            case "onkeypress":
            case "onkeydown":
            case "onkeyup":
            case "onload":
            case "onlosecapture":
            case "onpropertychange":
            case "onreadystatechange":
            case "onrowsdelete":
            case "onrowenter":
            case "onrowexit":
            case "onrowsinserted":
            case "onstart":
            case "onscroll":
            case "onbeforeeditfocus":
            case "onactivate":
            case "onbeforedeactivate":
            case "ondeactivate":
            case "type":
            case "codebase":
            case "id":
              ret.objAttrs[args[i]] = args[i+1];
              break;
            case "width":
            case "height":
            case "align":
            case "vspace":
            case "hspace":
            case "class":
            case "title":
            case "accesskey":
            case "name":
            case "tabindex":
              ret.embedAttrs[args[i]] = ret.objAttrs[args[i]] = args[i+1];
              break;
            default:
              ret.embedAttrs[args[i]] = ret.params[args[i]] = args[i+1];
        ret.objAttrs["classid"] = classid;
        if (mimeType) ret.embedAttrs["type"] = mimeType;
        return ret;
      </script>
      </head>
      <body bgcolor="#000000">
      <!--url's used in the movie-->
      <!--text used in the movie-->
      <!-- saved from url=(0013)about:internet -->
      AC_FL_RunContent(
        'codebase', 'http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,0,0',
        'width', '900',
        'height', '700',
        'src', 'bobbypic',
        'quality', 'high',
        'pluginspage', 'http://www.adobe.com/go/getflashplayer',
        'align', 'middle',
        'play', 'true',
        'loop', 'true',
        'scale', 'noscale',
        'wmode', 'window',
        'devicefont', 'false',
        'id', 'bobbypic',
        'bgcolor', '#000000',
        'name', 'bobbypic',
        'menu', 'true',
        'allowFullScreen', 'false',
        'allowScriptAccess','sameDomain',
        'movie', 'bobbypic',
        'salign', ''
        ); //end AC code
      </script>
      <noscript>
      <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,0,0" width="900" height="700" id="bobbypic" align="middle">
      <param name="allowScriptAccess" value="sameDomain" />
      <param name="allowFullScreen" value="false" />
      <param name="movie" value="bobbypic.swf" /><param name="quality" value="high" /><param name="scale" value="noscale" /><param name="bgcolor" value="#000000" /> <embed src="bobbypic.swf" quality="high" scale="noscale" bgcolor="#000000" width="900" height="700" name="bobbypic" align="middle" allowScriptAccess="sameDomain" allowFullScreen="false" type="application/x-shockwave-flash" pluginspage="http://www.adobe.com/go/getflashplayer" />
      </object>
      </noscript>
      </body>
      </html>
