1 Reply Latest reply on Jun 5, 2011 9:57 AM by UltimateFlashxz
    Flash Game Ground HELP!
    Wasin_Mike
      Hello all, I just started with flash and I'm pretty new to the language.
      I am currently making a game in flash and have a sprite that needs to jump up to platforms.
      He stands on the first rectangle I made but doesn't land on the others and passes right through them.
      I have changed the character code many times to no avail. I have tried other ways but he falls through the main ground platform when I change.
      Here's the code on my character, there is no code on the platforms. (I have tried coding the platforms which don't help either)
      onClipEvent (load) {
      speed = 8;
      isJumping = false;
      jumpSpeed = 0;
      startY = _y;
      scale = _xscale;
      onClipEvent (enterFrame) {
      if (isJumping) {
      _y += jumpSpeed;
      jumpSpeed += .86;
      if (_y>=startY) {
      _y = startY;
      isJumping = false;
      speed = 8;
      } else {
      if (Key.isDown(Key.UP)) {
      isJumping = true;
      jumpSpeed = -15;
      speed = 8;
      if (Key.isDown(Key.LEFT)) {
      play();
      _x -= speed;
      _xscale = -scale;
      } else {
      if (Key.isDown(Key.RIGHT)) {
      play();
      _x += speed;
      _xscale = scale;
      } else {
      stop();
      If there is more info I can provide to help, I will.
      Thank you.
        • 1. Re: Flash Game Ground HELP!
          UltimateFlashxz
          to have a game with Gravity, Jumping, and Ground Detection, first you need to make sure you enable all of these.
          GRAVITY-
          Gravity sounds weird and tricky but its also very simple.
          Theres a simple layout of code to enable Gravity.
               var Grav:Number = 0;
               var Gravity:Number = 5;
               _y += Grav;
               Grav += Gravity;
          What that does is adds a consistent pull on the MC you place it into. Adding a Gravity like effect.
          JUMPING-
          Jumping is also very simple once you've done it once or twice, and as i seen in your code you have.
          I will add Jumping to the previous code now.
               var maxJump:Number = -22
               _y += Grav;
               Grav += Gravity;
               Grav = maxJump;
          The maxJump variable is the height of the jump and can be modified to your liking, REMEMBER to always have the number as a minus - since flashes y axis is backwards.
          GROUND DETECTION-
          This is something i did not see in your code, which i believe it your issue.
          Ground Detection is very simple but hard to figure out with out good know how of Flash.
          First, make your Ground convert it to a MC, name it whatever you like.
          Second, set the Instance Name of your Ground MC, to "Ground" (no brackets).
          Third make sure all of you level/games ground is within this MC or within another MC with "Ground" as the Instance Name.
          I will add the Ground Detection to the previous code now.
               var touchingGround:Boolean = false;
               var Ground:MovieClip = _root.ground;
               _y += Grav;
               Grav += Gravity;
               while (Ground.hitTest(_x, _y, true)) {
                    _y -= Gravity;
                    Grav = 0;
               if (Ground.hitTest(_x, _y+5, true)) {
                    touchingGround = true;
               } else {
                    touchingGround = false;
               if (Key.isDown(Key.UP) && touchingGround){
                    Grav = maxJump;
          Take your time to learn this and study it and re-build it on your own, or just use it and add to it.
          Message was edited by: UltimateFlashxz
