5 Replies Latest reply on Jun 5, 2011 7:40 PM by adninjastrator
    FLV that won't display
    nyds0806 Level 1
      I created a DW CS5.5 file, (code is below) I embedded an FLV that won't play once the page is on the webserver, although in DW Liveview mode it plays fine.
      Please advise what I need to change to make this play on the server. The live page link:  www.kappythekangaroo.com/animation.html
      <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="320" height="240" id="FLVPlayer">
          <param name="movie" value="FLVPlayer_Progressive.swf" />
          <param name="quality" value="high">
          <param name="wmode" value="opaque">
          <param name="scale" value="noscale">
          <param name="salign" value="lt">
          <param name="FlashVars" value="&amp;MM_ComponentVersion=1&amp;skinName=Clear_Skin_1&amp;streamName=kappy&amp;autoPlay=true&amp;autoRewind=true" />
          <param name="swfversion" value="8,0,0,0">
          <!-- This param tag prompts users with Flash Player 6.0 r65 and higher to download the latest version of Flash Player. Delete it if you don’t want users to see the prompt. -->
          <param name="expressinstall" value="Scripts/expressInstall.swf">
          <!-- Next object tag is for non-IE browsers. So hide it from IE using IECC. -->
          <!--[if !IE]>-->
          <object type="application/x-shockwave-flash" data="FLVPlayer_Progressive.swf" width="320" height="260">
            <!--<![endif]-->
            <!-- The browser displays the following alternative content for users with Flash Player 6.0 and older. -->
            <div>
              <h4>Content on this page requires a newer version of Adobe Flash Player.</h4>
              <p><a href="http://www.adobe.com/go/getflashplayer"><img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" /></a></p>
            </div>
            <!--[if !IE]>-->
          </object>
          <!--<![endif]-->
        </object>
