So I have re-installed Flash Builder So when I try and run a Adobe air app from the Flash Builder It brings up a prompt everytime saying - If the program is already running, close it before attempting to run. When I kill the Adobe Air debugger in the Task manager it pops up again saying If the program is already running, close it before attempting to run.
After waiting a few moments from trying again I get a message: Unable to connect to the Application to fetch profile data. Please try profiling the application again.
With Flash based - web browser apps - they run fine with no issue. How ever its only adobe air - desktop apps that run this way. This is the third time I have installed FB 4.5 on Windows 7 64 bit. last night it was all woprking fine I was able to debug my Flash Application and everything was working - it has been doing this all day.
I shouls Also state I am running Flash 10.3 and Air 2.6 with FB 4.5 on Windows 7 64 bit.
Bump. I need help with this. I cannot launch any air apps from flash builder and there is nothing in the bin folder to launch and running the export as release build throws errors
Also - In my bin-debu when this runs as a air desktop (which it wont run (see previous posts)) all there is - as out put - is a main.swf and a mai-app.xml
nothing else.
Help Please I see 15 people read this.
Come on people lets go!!!! I cant figure out whats wrong with flashbuilder
I should also mention it no longer brings up that launching window that shows you its building the app - it also no longer shows you that its building the app in the lower right hand corner - it just shows the adobe air debugger in the windows task manager
22 and not one reply
Sounds like you have a stale Preloader entry in mm.cfg.
1. Find mm.cfg (http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf69084-7fc9.html will help).
2. Remove the PreloadSWF entry in the file, save it.
-Anirudh
I had the same issue suddenly today
After hours of scratching my head - and just before re-installing FlashBuilder 4.5 - I found this suggestion
I had an entry in the "mm.cfg" file:
PreloadSWF=C:\Users\<USERNAME>\AppData\Roaming\Mozilla\Firefox\Profiles\9us94hs0.default\extensions\flashfirebug@o-minds.com\chrome\content\flashfirebug\flashfirebug.swf
- I deleted the line and it now works
---- aaarrrrggghhh - wasted time
thanks
I restarted Firefox - and now the problem is back
I had to go to the file at:
C:\Users\<USERNAME>\mm.cfg
again
It must be a combination of flash-debug version/firebug/
don't have time to find out how to permanently sort this out without uninstalling firbug/flash debug version
have to much other work
