1 Reply Latest reply on Jun 6, 2011 12:14 AM by Hazar Hiasat
    when taking Image snapshot while changing the layout direction ,the characters is missing!
    Hazar Hiasat
      The application is a multilingual, so if the language choosen is arabic i changed the layout this.layoutDirection ="rtl";
      after doing so , if i tried to take an image snapshot the chart will miss all the charachters as shown below .
      if i comment this.layoutDirection ="rtl", the image snapshot will work fine!
      Any help please?!
      I am using Flex builder 4 , is this solved in flex builder 4.5?!
        • 1. Re: when taking Image snapshot while changing the layout direction ,the characters is missing!
          Hazar Hiasat Level 1
          Also , I tried to create the BitmapData , but the same problem
          //Code that i am using to generate ImageSnapshot
          var image:ImageSnapshot = ImageSnapshot.captureImage(this, 300, new PNGEncoder(), true);
          var file:FileReference = new FileReference();
          file.save(image.data, chartDescription +".png");
          //Code that i am using to generate BitmapData
          var bitmapData:BitmapData = new BitmapData (this.width,this.height);
          bitmapData.fillRect(new Rectangle (0,0,bitmapData.width,bitmapData.height),0x00000000);
          bitmapData.draw(this);
          var fileRef:FileReference = new FileReference();
          var encoder:PNGEncoder = new PNGEncoder();
          var data:ByteArray = encoder.encode(bitmapData);
          fileRef.save(data,chartDescription + ".png");
