16 Replies Latest reply on Jun 8, 2011 9:51 AM by learner_doug
    Syntax Error:  Expecting semicolon before colon
    learner_doug Level 1
      Can't see were I made a mistake.  Perhaps another set of eyes may help.  I went over this many man times, but can't seem to see my error.  Thanks for your assistance.
        • 1. Re: Syntax Error:  Expecting semicolon before colon
          UbuntuPenguin Level 4
          Are you using a switch statement ? Is the colon in the wrong place ?
          Do you have something like this
          public function getSomething():Array; <------ superfluous semicolon
          Those are the syntactical errors that come to mind of the top of my head.
          • 2. Re: Syntax Error:  Expecting semicolon before colon
            pauland Level 4
            My crystal ball is a bit fuzzy today, so I can't see your code clearly.
            Did you leave off a semicolon at the end of the previous line?
            • 3. Re: Syntax Error:  Expecting semicolon before colon
              No, I don't think so.  Here is the code if you have a minute.
              Thanks for your response.
              import flash.events.Event;
              var ow1Text:String = "1. Queue";
              var ow1toolTip:String = "-Order enters COMIT from the CTS Web Center\n-Assigned Staff queries COMIT Tracking for unassigned orders and assigns orders to an Order Writer";
              var ow2Text:String = "2. Reseasrch & Verify Order";
              var ow2toolTip:String = "";
              var ow3Text:String = "3. Weekly Converence Call";
              var ow3toolTip:String = "";
              var ow4Text:String = "4. Create Project/Service Order(s)";
              var ow4toolTip:String = "";
              var ow5Text:String = "5. Prepare Order Package";
              var ow5toolTip:String = "";
              var ow6Text:String = "6. Complete and Assign in COMIT Tracking";
              var ow6toolTip:String = "";
              var ow7Text:String: = "";
              var ow7toolTip:String = "";
              var ow8Text:String: = "";
              var ow8toolTip:String = "";
              var ow9Text:String: = "";
              var ow9toolTip:String = "";
              var ow10Text:String = "";
              var ow10toolTip:String = "";
              var ow11Text:String = "";
              var ow11toolTip:String = "";
              var ow12Text:String = "";
              var ow12toolTip:String = "";
              var ow13Text:String = "";
              var ow13toolTip:String = "";
              var ow14Text:String = "";
              var ow14oolTip:String = "";
              var ow15Text:String = "";
              var ow15toolTip:String = "";
              var ow16Text:String = "";
              var ow16toolTip:String = "";
              var ow17Text:String = "";
              var ow17toolTip:String = "";
              var ow18Text:String = "";
              var ow18toolTip:String = "";
              var ow19Text:String: = "";
              var ow19toolTip:String = "";
              var ow20Text:String = "20. Complete COMIT Tracking";
              var ow20toolTip:String = "";
              var ow21Text:String = "";
              var ow21toolTip:String = "";
              var ow22Text:String: = "";
              var ow22toolTip:String = "";
              var ow23Text:String = "";
              var ow23toolTip:String = "";
              var ow24Text:String = "";
              var ow24toolTip:String = "";
              //  Populate the TextAreas with text and tooltips
              public function addText(event:Event):void
              ow1.text = ow1Text;
              ow1.toolTip = ow1toolTip;
              ow2.text = ow2Text;
              ow2.toolTip = ow1toolTip;
              ow3.text = ow3Text;
              ow3.toolTip = ow3toolTip;
              ow4.text = ow2Text;
              ow4.toolTip = ow1toolTip;
              ow5.text = ow2Text;
              ow5.toolTip = ow1toolTip;
              ow6.text = ow2Text;
              ow6.toolTip = ow1toolTip;
              ow7.text = ow2Text;
              ow7.toolTip = ow1toolTip;
              ow8.text = ow8Text;
              ow8.toolTip = ow8toolTip;
              ow9.text = ow9Text;
              ow9.toolTip = ow9toolTip;
              ow10.text = ow10Text;
              ow10.toolTip = ow10toolTip;
              ow11.text = ow11Text;
              ow11.toolTip = ow11toolTip;
              ow12.text = ow12Text;
              ow12.toolTip = ow12toolTip;
              ow13.text = ow13Text;
              ow13.toolTip = ow13toolTip;
              ow14.text = ow14Text;
              ow14.toolTip = ow14toolTip;
              ow15.text = ow15Text;
              ow15.toolTip = ow15toolTip;
              ow16.text = ow10Text;
              ow16.toolTip = ow16toolTip;
              ow17.text = ow10Text;
              ow17.toolTip = ow17toolTip;
              ow18.text = ow18Text;
              ow18.toolTip = ow18toolTip;
              ow19.text = ow19Text;
              ow19.toolTip = ow19toolTip;
              ow20.text = ow20Text;
              ow20.toolTip = ow20toolTip;
              ow21.text = ow21Text;
              ow21.toolTip = ow21toolTip;
              ow22.text = ow20Text;
              ow22.toolTip = ow22toolTip;
              ow23.text = ow23Text;
              ow23.toolTip = ow23toolTip;
              ow24.text = ow24Text;
              ow24.toolTip = ow24toolTip;
              • 4. Re: Syntax Error:  Expecting semicolon before colon
                Thank you for helping.
                ow1.text = ow1Text;
                ow2.text = ow2Text;
                ow3.text = ow3Text;
                ow4.text = ow2Text;
                ow5.text = ow2Text;
                ow6.text = ow2Text;
                ow7.text = ow2Text;
                ow8.text = ow8Text;
                ow9.text = ow9Text;
                • 5. Re: Syntax Error:  Expecting semicolon before colon
                  Where is the line it is complaining about ?
                  • 6. Re: Syntax Error:  Expecting semicolon before colon
                    See in red below.  All generating the same error.
                    ow1.text = ow1Text;
                    ow2.text = ow2Text;
                    ow3.text = ow3Text;
                    ow4.text = ow2Text;
                    ow5.text = ow2Text;
                    ow6.text = ow2Text;
                    ow7.text = ow2Text;
                    ow8.text = ow8Text;
                    ow9.text = ow9Text;
                    • 7. Re: Syntax Error:  Expecting semicolon before colon
                      pauland Level 4
                      Seeing the red on a list that has none, is a bit tricky.
                      Usually the first error is the place to start.
                      • 8. Re: Syntax Error:  Expecting semicolon before colon
                        I think there is a bug in Flash Builder.  I'm going to run this on another machine to see what happens.
                        Thanks again!
                        Doug
                        • 9. Re: Syntax Error:  Expecting semicolon before colon
                          This is crazy,
                          FYI: I simplified the AS file, with a script of only 17 lines, it throws errors on line 19 which doesn't even exist.  I think FlashBuilder is buggy.
                          • 10. Re: Syntax Error:  Expecting semicolon before colon
                            Penguin,
                            No switch statements in this one.
                            Thanks.
                            • 11. Re: Syntax Error:  Expecting semicolon before colon
                              pauland Level 4
                              I suspect you'll kick yourself when you solve it.
                              Give us a clue as to where the first line is that has an error. You aren't making it easy to help you.
                              • 12. Re: Syntax Error:  Expecting semicolon before colon
                                Ha Ha, I've already kicked things!
                                • 13. Re: Syntax Error:  Expecting semicolon before colon
                                  pauland Level 4
                                  BTW when you do fix it, please check the spelling in your messages!
                                  • 14. Re: Syntax Error:  Expecting semicolon before colon
                                    Thank you for pointing that out.
                                    • 15. Re: Syntax Error:  Expecting semicolon before colon
                                      _spoboyle Level 4
                                      should be
                                      var ow7Text:String = "";
                                      var ow8Text:String = "";
                                      var ow9Text:String = "";
                                      var ow19Text:String = "";
                                      var ow22Text:String = "";
                                      • 16. Re: Syntax Error:  Expecting semicolon before colon
                                        Hard to believe I missed that.  Thanks again.
                                        Doug
