This content has been marked as final.
Show 1 reply
1. Re: Error when switching between drafts: "The instruction at "0x009f6487" ...
Dominic Michael Jun 13, 2011 1:28 AM (in response to RickEEE)Can you please try clearning the Contribute preferences?
To Clear the preference, quit Contribute, and then delete the Contribute CS3 folder in C:\Documents and Settings\<user>\Local Settings\Application Data\Adobe\ and also run the following command " reg delete "HKCU\Software\Adobe\Contribute 4.1" /f " if you are using Contribute CS3. Reconnect to the site and try the same scenario.
Note that, if you clear the preferences then no connection will be listed in Contribute, you need to recreate the connections. It will be like a fresh installation.
