1 Reply Latest reply on Jun 7, 2011 6:33 PM by robdillon
    Scrollpanel/trackskin editting
    rhtmxhq8
      Im trying to get rid of the track that is used in scroll panel. It seems that I have no way to remove it.
      I tried checking visible to false,alpha=0,and color to white. It wont affect the skin track at all in the scroll panel.
      This is flash cs5.5 as3.0. Using component:scrollpanel
        • 1. Re: Scrollpanel/trackskin editting
          robdillon Most Valuable Participant
          Go to the Library and look at the last item in the ScrollBarSkins folder in the Component Assets folder. It should be named ScrollTrack_skin. You can edit this movieClip. You can remove the fill or set it to a 0 alpha. This will edit the background for both the vertical and the horizontal scrollbars.
