1 Reply Latest reply on Jun 7, 2011 1:44 PM by Flex harUI
    Conditional Compiling Flex 3.2 vs Flex 4.5
    Jay_Ds
      I was considering conditional compiling so the old flex 3 code stays the same, and flex 4.5 has the changes.  This would avoid a problematic merge at the end and allow the old code to work for a while longer.
      However, I have some changes that aren't working in flex 3.2 (eclipse 3.4).  From eclipse, the optional Compile options are set to:
        -define+=CONFIG::flex3,"false"  -define+=CONFIG::flex4,"true"
      My test code is:
      CONFIG::flex3 {
                      var sort:Sort = collection.sort;
      CONFIG::flex4 {
                      var sort:ISort = collection.sort;
      This works if flex4 but gives me the following under flex 3.
      1120: Access of undefined property flex3.
      Any ideas?  Is this doable?
