I have problems working through the tutorial.http://files.zend.com/help/Flash-Builder-for-PHP/Getting-Started/Mobile/building_your_first_php-base...
I get the following error message at the step 12 where you test the service you created from the tutorial.
InvocationTargetException:There was an error while invoking the operation. Check your server settings and try invoking the operation again.
Reason: Server error Class "EmployeeService" does not exist: Plugin by name 'EmployeeService' was not found in the registry; used paths: : /Users/sebey/Sites/zend/exampleMobileAndPHP/htdocs/ #0 /Users/sebey/Programmierung/workspaceFB4.5/.metadata/.plugins/org.zend.php.framework.resource/resources/ZendFramework-1/library/Zend/Amf/Server.php(553): Zend_Amf_Server->_dispatch('getEmployees', Array, 'EmployeeService') #1 /Users/sebey/Programmierung/workspaceFB4.5/.metadata/.plugins/org.zend.php.framework.resource/resources/ZendFramework-1/library/Zend/Amf/Server.php(629): Zend_Amf_Server->_handle(Object(Zend_Amf_Request_Http)) #2 /Users/sebey/Sites/zend/exampleMobileAndPHP/htdocs/gateway.php(68): Zend_Amf_Server->handle() #3 {main}
The only difference from my project to the test is that I've use a vhost for my php files and put the gateway.php and amf_config.ini in the "htdocs" folder of my vhost root. The vhost is reachable and when I put EmployeeService.php in htdocs it is found and the test succeds. But why isn't it searching in the services folder...
Anybody?
thx a lot
Add the services directory into the amf_config.ini which is in folder public
To do that add the line
amf.directories[]=../services
