3 Replies Latest reply on Jun 8, 2011 6:38 AM by Alberto_Mz_Dz
    Unload swf file using SWFLoader
    Alberto_Mz_Dz
      I have a main application where I am using a SWFLoader to load a second application.
      In the second application I want to put a button (Close) and when I click it I want to unload this application.
      Is it possible to achieve this?
      I know that I can unload a swf file using the unloadAndStop method of SWFLoader, but how can I access it from the loaded application?
      I think that another approach would be adding eventlisteners to loaded swf but I am not sure how to do that.
      Does anyone can help me?
      Thanks in advance,
      Alberto
        • 1. Re: Unload swf file using SWFLoader
          Ankur Arora Level 1
          Use SWFloaderInstance.content property to get to loaded SWF. You should have a public method in loaded SWF which will unload internal swf. Call that method by MovieClip(SWFloaderInstance.content).unloadInternalSWFs();
          Let me know if you need any other help.
          Ankur Arora
          Flex & Flash expert
          • 2. Re: Unload swf file using SWFLoader
            blazejewicz Level 4
            @Alberto
            I think you could use custom or built-in event type to dispatch information to hosting application and SWFLoader *has* built-in dedicated routine to unload loaded context - which includes removing event listeners added to swf-types on content load (Yes, there are means in Flex SDK to access top-most application but usually that is not advised to access methods/properties of parent as it closely ties content together).
            So your parent application could start to listen for custom event when load completes and removes loaded app that way:
                              xmlns:mx="library://ns.adobe.com/flex/mx">
                 <fx:Script>
                      <![CDATA[
                           protected function chidLoadedHandler(event:Event):void
                                swfLoader.content.addEventListener(Event.CLOSE, unloadChildHandler);
                           protected function unloadChildHandler(event:Event):void
                                swfLoader.content.removeEventListener(Event.CLOSE, unloadChildHandler);
                                swfLoader.unloadAndStop(true);
                 </fx:Script>
                 <s:SWFLoader
                      width="100%" height="100%"
                      source="ChildApplication.swf"
                      complete="chidLoadedHandler(event)"
                      id="swfLoader"/>
            </s:Application>
            while your child application simply:
                 <fx:Script>
                      <![CDATA[
                           protected function unloadMeHandler(event:MouseEvent):void
                                // we will dispatch "CLOSE" event - this could be custom event type
                                // but I think it is just enoguht heres
                                var closeEvent:Event = new Event(Event.CLOSE);
                                // root is top-most - so it is "content" top-most display object as well
                                this.root.dispatchEvent(closeEvent);
                 </fx:Script>
                 <!-- ui -->
                 <s:Button x="10" y="10" label="Unload me" click="unloadMeHandler(event)" id="unloadButton"/>
            </s:Application>
            Not sure if that is most bullet proof or recommended solution but could be place to start,
            regards,
            Peter
            • 3. Re: Unload swf file using SWFLoader
              Alberto_Mz_Dz Level 1
              Hi Peter,
              Thanks for the info, it was very helpful.
              That's what I needed.
              Regards,
              Alberto
