5 Replies Latest reply on Jun 8, 2011 4:19 AM by Dragos0806
    Library project assets
    Dragos0806
      Hello
      Im working on a project and i want to make it very easy to complie it for all platforms
      I made a Flex Library with 2 folders: classes and assets
      In the main project i can access the classes without problems, but i can't access assets
      In assets i have XMLs and JPGs
      My last try was adding the assets folder (from lib) as linked folder (to main)
      In the main project i have this code
              <fx:XML id="XMLvar1" source="assets/config/1.xml" />
              <fx:XML id="XMLvar2" source="assets/config/2.xml" />
      This is working!!
      But the images, for example
      <s:Image x="667" y="688" source="assets/images/img103.jpg"/>
      Is not showing
      Any idea why ?
        • 1. Re: Library project assets
          _spoboyle Level 4
          it will depends on your project folder structure
          can you post that here
          you will probably need to either add the assets directory directly to your source path
          project properties->Flex build path->Source path->Add Folder
          or
          assuming the assets directory is parallel to your src folder
          use <fx:XML id="XMLvar1" source="../assets/config/1.xml" />
          • 2. Re: Library project assets
            Dragos0806 Level 1
            my structure is like this
            main_project
                 src
            lib_project
                 src
                      assets
                      classes
            When i linked the folder assets to main_project i could see the image in the designer using path with ../assets/image/...
            But when i ran the app, the image didnt show. My guess is that images are not copied on build, but the XMLs are
            When i add the folder assets to main_project as source path the structure of main_project becomes
            main_project
                 [source paths] assets
                                          config (here i have xmls)
                                          images
                 src
            But i can't link the XMLs with the code
                    <fx:XML id="XML1" source="assets/config/1.xml" />
                    <fx:XML id="XML2" source="assets/config/2.xml" />
            I get Problem finding external XML, even if i put ../assets..
            Whats the right linking way when adding a folder as source path ?
            • 3. Re: Library project assets
              _spoboyle Level 4
              ok based on that structure the ../assets i said is wrong and they way you did it originally should work as far as I am aware.
              since the assets folder is within the src folder it will already be added to the source path.
              you could try  <fx:XML id="XML1" source="/assets/config/1.xml" />
              but beyond that I am a little stumped. I might be able to find time to setup a project similar to yours a little later if i can replicate the issue i'll get back you you with a fix
              • 4. Re: Library project assets
                Dragos0806 Level 1
                That would be great
                Please try put a image and a XML in a library project and load xml and display image in the main
                The main problem are the images.. never got a way to show them.
                To the xml i had access on a few configurations
                • 5. Re: Library project assets
                  Dragos0806 Level 1
                  I finaly managed
                  The solution was to go on main_project -> flex build path ->source path
                  and add there lib_project/src
                  And no selecting the lib_project in flex build path/library path
