flexunit CIListener: Socket tiimeout waiting for flexunit report
sookkie Jun 9, 2011 6:36 PMFor 2 weeks , I have trouble establising CI enviroment.
My env :
sdk : flex sdk 4.1
ant : 1.8.2
I got the FlexUnit4SampleCIProject .
and modified the build.xml
ant then always get the error
java.util.concurrent.ExecutionException: Socket tiimeout waiting for flexunit report
I think that CIListener is not working but I'm not sure the reason .
please, give me a help ~
Hudson CI Server message follows:
Started by user anonymous
Checking out a fresh workspace because there's no workspace at C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace
Checking out http://10.177.50.39/svn/TVSIGNAGE/trunk/src/01_CI_Sample/FlexUnit4SampleCIProject
A build.browser.xml
A .project
A build.custom.xml
A src
A src\test
A src\test\flex
A src\test\flex\AirTestRunner.mxml
A src\test\flex\TestRunner.mxml
A src\test\flex\org
A src\test\flex\org\flexunit
A src\test\flex\org\flexunit\demo
A src\test\flex\org\flexunit\demo\EchoPanelTest.as
A src\test\flex\org\flexunit\demo\SampleTest.as
A src\main
A src\main\flex
A src\main\flex\Main.mxml
A src\main\flex\org
A src\main\flex\org\flexunit
A src\main\flex\org\flexunit\demo
A src\main\flex\org\flexunit\demo\EchoPanel.mxml
A build.air.xml
A .flexProperties
A libs
AU libs\flexUnitTasks-4.1.0-8.jar
AU libs\flexunit-4.1.0-8-as3_4.1.0.16076.swc
AU libs\flexUnitTasks-4.1.0-8-sources.jar
AU libs\flexunit-cilistener-4.0.0.swc
AU libs\flexUnitTasks-4.1.0-8-javadoc.jar
AU libs\flexunit-aircilistener-4.1.0-8-4.1.0.16076.swc
AU libs\flexunit-uilistener-4.0.0.swc
AU libs\flexunit-4.1.0-8-flex_4.1.0.16076.swc
AU libs\flexunit-cilistener-4.1.0-8-4.1.0.16076.swc
AU libs\fluint-extensions-4.1.0-8-4.1.0.16076.swc
AU libs\flexunit-flexcoverlistener-4.1.0-8-4.1.0.16076.swc
AU libs\flexunit-uilistener-4.1.0-8-4.1.0.16076.swc
A pom.xml
A README.txt
A .actionScriptProperties
A html-template
A html-template\AC_OETags.js
A html-template\history
A html-template\history\historyFrame.html
A html-template\history\history.css
A html-template\history\history.js
AU html-template\playerProductInstall.swf
A html-template\index.template.html
A build.xml
At revision 57
[workspace] $ cmd.exe /C '"ant.bat && exit %%ERRORLEVEL%%"'
Buildfile: C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\build.xml
init:
[mkdir] Created dir: C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\target
[mkdir] Created dir: C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\target\bin
[mkdir] Created dir: C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\target\report
[mkdir] Created dir: C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\target\dist
compile:
[mxmlc] 구성 파일 C:\flex_sdk_4.0.0.14159\frameworks\flex-config.xml을(를) 불러오는 중
[mxmlc] C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\target\bin\Main.swf(58142바이트)
test:
[flexunit] Validating task attributes ...
[flexunit] Generating default values ...
[flexunit] Using the following settings for compilation:
[flexunit] FLEX_HOME: [C:\flex_sdk_4.0.0.14159]
[flexunit] player: [flash]
[flexunit] sourceDirectories: ["C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\src\main\flex"]
[flexunit] testSourceDirectories: ["C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\src\test\flex"]
[flexunit] libraries: ["C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-4.1.0-8-as3_4.1.0.16076.swc","C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-4.1.0-8-flex_4.1.0.16076.swc","C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-aircilistener-4.1.0-8-4.1.0.16076.swc","C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-cilistener-4.0.0.swc","C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-cilistener-4.1.0-8-4.1.0.16076.swc","C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-flexcoverlistener-4.1.0-8-4.1.0.16076.swc","C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-uilistener-4.0.0.swc","C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-uilistener-4.1.0-8-4.1.0.16076.swc","C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\fluint-extensions-4.1.0-8-4.1.0.16076.swc"]
[flexunit] Found SDK version: 4
[flexunit] Created test runner at [C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\target\bin\TestRunner.mxml]
[flexunit] Compiling test classes: [org.flexunit.demo.EchoPanelTest, org.flexunit.demo.SampleTest]
[flexunit] Executing 'C:\Java\jdk1.6.0_25\jre\bin\java.exe' with arguments:
[flexunit] '-Xmx256M'
[flexunit] '-jar'
[flexunit] 'C:\flex_sdk_4.0.0.14159\lib\mxmlc.jar'
[flexunit] '+flexlib'
[flexunit] 'C:\flex_sdk_4.0.0.14159\frameworks'
[flexunit] '-output'
[flexunit] 'C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\target\bin\TestRunner.swf'
[flexunit] '-source-path'
[flexunit] 'C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\src\main\flex'
[flexunit] 'C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\src\test\flex'
[flexunit] '-library-path+=C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-4.1.0-8-as3_4.1.0.16076.swc'
[flexunit] '-library-path+=C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-4.1.0-8-flex_4.1.0.16076.swc'
[flexunit] '-library-path+=C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-aircilistener-4.1.0-8-4.1.0.16076.swc'
[flexunit] '-library-path+=C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-cilistener-4.0.0.swc'
[flexunit] '-library-path+=C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-cilistener-4.1.0-8-4.1.0.16076.swc'
[flexunit] '-library-path+=C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-flexcoverlistener-4.1.0-8-4.1.0.16076.swc'
[flexunit] '-library-path+=C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-uilistener-4.0.0.swc'
[flexunit] '-library-path+=C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\flexunit-uilistener-4.1.0-8-4.1.0.16076.swc'
[flexunit] '-library-path+=C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\libs\fluint-extensions-4.1.0-8-4.1.0.16076.swc'
[flexunit] '-debug=false'
[flexunit] '-headless-server=true'
[flexunit] 'C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\target\bin\TestRunner.mxml'
[flexunit]
[flexunit] The ' characters around the executable and arguments are
[flexunit] not part of the command.
[flexunit]
[null] 구성 파일 C:\flex_sdk_4.0.0.14159\frameworks\flex-config.xml을(를) 불러오는 중
[null] C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\target\bin\TestRunner.swf(104051바이트)
[flexunit] Using the following settings for the test run:
[flexunit] haltonfailure: [false]
[flexunit] headless: [false]
[flexunit] display: [99]
[flexunit] localTrusted: [true]
[flexunit] port: [1024]
[flexunit] swf: [C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\target\bin\TestRunner.swf]
[flexunit] timeout: [15000ms]
[flexunit] toDir: [C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\target\report]
[flexunit] Setting up server process ...
[flexunit] Starting server ...
[flexunit] Updated local trust file at [C:\Documents and Settings\yoonsook.kim\Application Data\Macromedia\Flash Player\#Security\FlashPlayerTrust\flexUnit.cfg], added [C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\target\bin].
[flexunit] Executing 'rundll32' with arguments:
[flexunit] 'url.dll,FileProtocolHandler'
[flexunit]
[flexunit]
[flexunit] Opening server socket on port [1024].
[flexunit] Waiting for client connection ...
[flexunit]
[flexunit] Stopping server ...
[flexunit] End of test data reached, sending acknowledgement to player ...
[flexunit] Closing client connection ...
[flexunit] Closing server on port [1024] ...
BUILD FAILED
C:\Documents and Settings\yoonsook.kim\.hudson\jobs\01_CI_Sample\workspace\build.xml:67: java.util.concurrent.ExecutionException: Socket timeout waiting for flexunit report
at java.util.concurrent.FutureTask$Sync.innerGet(FutureTask.java:222)
at java.util.concurrent.FutureTask.get(FutureTask.java:83)
at org.flexunit.ant.tasks.TestRun.run(Unknown Source)
at org.flexunit.ant.tasks.FlexUnitTask.execute(Unknown Source)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:390)
at org.apache.tools.ant.Target.performTasks(Target.java:411)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
at org.apache.tools.ant.Main.runBuild(Main.java:809)
at org.apache.tools.ant.Main.startAnt(Main.java:217)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:280)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:109)
Caused by: Socket timeout waiting for flexunit report
at org.flexunit.ant.FlexUnitSocketServer.start(Unknown Source)
at org.flexunit.ant.FlexUnitSocketThread.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.net.SocketTimeoutException: Accept timed out
at java.net.PlainSocketImpl.socketAccept(Native Method)
at java.net.PlainSocketImpl.accept(PlainSocketImpl.java:408)
at java.net.ServerSocket.implAccept(ServerSocket.java:462)
at java.net.ServerSocket.accept(ServerSocket.java:430)
at org.flexunit.ant.FlexUnitSocketServer.openClientSocket(Unknown Source)
... 7 more
Total time: 30 seconds
Finished: FAILURE
