1 Reply Latest reply on Jun 8, 2011 9:21 AM by Scott Worthington
    How can I export a smallformat flatten PDF-file with transparant parts in?
    fl_vdb
      My post on a PDF - more clear with images (english):
      http://www.logicontrol.be/gallery/documents/help-eng.pdf
      Deze post in nederlandstalige versie:
      http://www.logicontrol.be/gallery/documents/help-nl.pdf
      Scope?
      I'dd like to export an Indesign-file (.indd) to a PDF-file that has to be:
      - the smallest possible file size
      - which displays images and text sharp on the screen
      - which also certainly remain transparent parts of .psd-files after exporting
      - that is flattened for easy print
      The problem?
      How and with which of settings can I export such a file from InDesign 5.0?
      If necessary in combination with some settings (after exporting) in our Adobe Acrobat 9 Pro?
      Further explanation
      The export file contains lots of text, graphics, photographs and drawings. Many of these items are .psd-files that contain transparent areas. The intention is that this transparent parts actually remain transparent even after exporting/flattening /decreasing the PDF.
      With InDesign 5.0?
      In the window Export Adobe PDF: (images see: http://www.logicontrol.be/gallery/documents/help-eng.pdf )
      Should I start from a default PDF preset   (if yes > which one??)
      Possibilities are: High Quality Print / PDFX-1a: 2001 / PDFX-3:2002 / PDFX-4:2007 / Press Quality / Smallest File Size
      Or is it better to create a PDF preset on my own?     (if yes > which settings??)
      Standard > PDF/X-format?
      Compatibility > PDF-version?
      Compression > If artwork should be compressed and downsampled, and if so,
                              which method and settings to I have to use
      Ouput > How can I control colors and PDF/X output intent profiles in the PDF-file?
      Advanced > How can I control fonts, OPI specifications, transparency flattening, and JDF instructions are
                        in the PDF file?
      With Adobe Acrobat 9 Pro?
      How can I reduce the file size extra, so more reducing after exporting into PDF ?
      How can I flatten the exported file (if not done during the export) ?
      !! Important, when I export/reduce/flatten the file, I ‘dd like that the parts of images who were transparent before, stays also transparent after !!
      WHAT CAN I DO ??
