2 Replies Latest reply on Jun 9, 2011 6:21 AM by AhmedCogenli
    Strange problem with keyboard event listener
    AhmedCogenli
      I have a full screen touchscreen app. For closing application I've set a keyboard event listener for "0" key. I don't want the user press Alt+F4 key combination due to some restrictions. Problems starts when the application loses the focus. Here is the code;
                  protected function onComplete(event:FlexEvent):void
                      this.setFocus();
                      this.addEventListener(KeyboardEvent.KEY_DOWN,trapKeys,true, 0, true );
                  private function trapKeys(e:KeyboardEvent):void {
                      if (e.keyCode == 96) {
                          this.close();
                      else if (e.keyCode == 48) {
                          this.close();
      When user change the screen to a different app with Alt+TAB or any other key combination flex app loses the focus and when he turns back to my app "0" doesn't work. How can I solve this issue?
      Thanks in advance.
        • 1. Re: Strange problem with keyboard event listener
          blazejewicz Level 4
          Hi Ahmed,
          I've absolutely no issue with solution you're trying to implement - are you using full screen with keyboard interactive mode?
          Please consider:
          // on complete add keyboard listener
          protected function applicationCompleteHandler(event:FlexEvent):void
               this.stage.addEventListener(KeyboardEvent.KEY_DOWN, trapKeys);
          protected function applicationActivateHandler(event:AIREvent):void
               if(this.stage)
                    // switch display state to full screen when activated
                    if(this.stage.displayState != StageDisplayState.FULL_SCREEN_INTERACTIVE)
                         this.stage.displayState = StageDisplayState.FULL_SCREEN_INTERACTIVE;
          private var exitHandled:Boolean = false;
          // on NUMBER_0 || NUMPAD_0 exit/close
          protected function trapKeys(event:KeyboardEvent):void
               if((event.keyCode == Keyboard.NUMBER_0
                    || event.keyCode == Keyboard.NUMPAD_0)
                    && this.exitHandled == false)
                    exitHandled = true;
                    this.stage.removeEventListener(KeyboardEvent.KEY_DOWN, trapKeys);
                    this.close();
          (note: applicaton "applicatonComplete" and "applicationActivate" events are routed to above handlers)
          regards,
          Peter
          • 2. Re: Strange problem with keyboard event listener
            AhmedCogenli Level 1
            Peter, thanks a lot, your code works perfect. I think applicationActivateHandler does the trick. Thanks a lot
