3 Replies Latest reply on Jun 13, 2011 11:59 AM by divinewind
    Placing Library Assets & Grouping for Resize - NEED HELP
    divinewind
      Hey there community,
      normally I wouldn't need to ask for help but this one is stumbling me beyond no end.
      I am building a script that receives the amount of spot colours in a job from sales via XML file and automatically put the swatches for the job on the proof 1 under the next and resized in a box.
      We have all the swatches in an Indesign Library file and I will have the colours used going through a loop and adding the proper swatch from the library onto the page 1 by 1 underneath each other.
      The trouble I am having is adding each placed asset into a group with the previously added library item so that I can select the group and resize it proportionally to fit in a specific area.
      Here is a mockup of the proposed code (with sensitive information stripped):
      myLibPath = "library location here";
      myLibrary = app.open(myLibPath);
      //starting location for swatches to appear on page
      var x = 5.2503;
      var y = 1.2913;
      //loop starts going through all the colours from an xml file and places each one
      **loop start here
           t=app.libraries.item("library name here").assets.item("itemname").placeAsset(app.activeDocument);
           t[0].move([x,y+.20]);  //the swatches are placed .20 inches lower than the previous one until finished
      **loop ends here
      What would I put in the loop to add the currently placing item into a group and then after the loop is done resize the entire group proportionally to say 3 inches high?
      ive tried with some digging throughout this forum for a solution and got this, but it just doesnt want to work.
      g=myPage.groups.add(t);  (of course myPage was defined earlier)
      Hopefully you geniuses can help me.
      Divine
        • 1. Re: Placing Library Assets & Grouping for Resize - NEED HELP
          John Hawkinson Level 5
          Hi, Divine:
          You haven't explained what goes wrong when you try your code. That would be helpful information.
          Anyhow, it looks like this strategy:
          // **loop start here
            //one until finished
          // **loop ends here
          Isn't quite going to work. Because:
          1. You don't increment y each time.
          2. You are going to make the items in t a group, but t only contains the last placed asset, not all of them.
          So I think you want something like this:
          var allt = [];
            allt.push(t[0]);
            t[0].move([x,y]);
            y += 0.20;
          // **loop ends here
          Though perhaps you'll have to do something fancier if there are multiple  items in the asset, since t[0] only gets you the first one.
          • 2. Re: Placing Library Assets & Grouping for Resize - NEED HELP
            anabasa@hotmail.com Level 1
            I'm not entirely sure of this answer but some part of it might come handy (not sure I completelly understood the question anyway).
            How about asigning a tag sequenced tag to each asset and make selection of all the assets, then group?
            As said, just an idea... Hope it helps
            • 3. Re: Placing Library Assets & Grouping for Resize - NEED HELP
              divinewind Level 1
              Thanks John, your suggestion worked like a charm and the grouping that was giving me problems worked flawlessly.
              Now just to figure out how to scale the group proportionally and I'm gold!
              Thanks once again!
