2 Replies Latest reply on Jun 8, 2011 6:01 PM by Joel Cherney
      • 1. Re: Is it possible to lock areas of an InDesign template so users can't make changes to those areas?
        Grant H Level 4
        this will kinda work
        you could create 2 ID documents. Locked.indd and editable.indd.
        Locked one you layout all the protected stuff, place it (so that it linked... duh) in the editable one in which you create whatever you want people to be able to edit. Lock the position of the linked indd doc and the layer even... not perfect but workable
        G
        • 2. Re: Is it possible to lock areas of an InDesign template so users can't make changes to those areas?
          Joel Cherney Level 5
          The upshot of this is that if you don't distribute the linked editable.indd InDesign file, the users get a low-res preview in locked.indd in which text is basically illegible, and if you give 'em the linked InDesign file, they can edit it with impunity. But, yeah, any restrictive locked-down workflow in ID would require a workaround like this. I sometimes make deliberately bad PDFs that are hard to edit in Acrobat and place those into InDesign.
          If you specify what you want to lock down, and whom you want to prevent from making changes, then maybe someone can specify a workaround that is more applicable to your situation. The suggestion that makes the most sense is InCopy, if you want people to edit text but not anything else, or if you want to "check out" particular parts of an InDesign file.
