0 Replies Latest reply on Nov 14, 2006 8:07 PM by alewis2006
    Flex 2 XML Namespaces and Action Script
    alewis2006
      Ok I have a couple of custom Componenets that reside in my Components folder in my flex project.
      I tried the example of lets say a modal title window....file named MyLoginForm.mxml
      <code for MyLoginForm component in the Componenets Directory>
      <?xml version="1.0"?>
      <mx:TitleWindow xmlns:mx=" http://www.adobe.com/2006/mxml" creationComplete="doInit();">
      <mx:Script>
      <![CDATA[
      import mx.managers.PopUpManager;
      private function doInit():void {
      // Center the TitleWindow container
      // over the control that created it.
      PopUpManager.centerPopUp(this);
      private function processLogin():void {
      // Check credentials (not shown) then remove pop up.
      PopUpManager.removePopUp(this);
      </mx:Script>
      <mx:Form>
      <mx:FormItem label="User Name">
      <mx:TextInput id="username" width="100%"/>
      </mx:FormItem>
      <mx:FormItem label="Password">
      <mx:TextInput id="password" displayAsPassword="true" width="100%"/>
      </mx:FormItem>
      </mx:Form>
      <mx:HBox>
      <mx:Button click="processLogin();" label="OK"/>
      <mx:Button click="PopUpManager.removePopUp(this);" label="Cancel"/>
      </mx:HBox>
      </mx:TitleWindow>
      </END CODE>
      From the application file MySystem.mxml I can get this to work if I put my componenet in the root of the application
      however it does not work if MyLoginForm component is where it should be in the componenets folder.Question is if I create a reference variable lets say var _myform=MyLoginForm;I get the same error as with the MyLoginForm not being in the root of the app.MyLoginForm not found.How do I refernce this file if it is in another directory.I know how xmlns work .If I hade a compnenet lets say Test.mxml in the components folder I could refernce it on this main app like xmlns:MyNamespace="Componenets.*" and then a control like <MyNamespace:Test />
      So how do I do this issue????
      <code>
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml">
      <mx:Script>
      <![CDATA[
      // Import the PopUpManager.
      import mx.core.IFlexDisplayObject;
      private function showLogin():void {
      // Create a non-modal TitleWindow container.
      var helpWindow:IFlexDisplayObject =
      PopUpManager.createPopUp(this, MyLoginForm, false);
      </mx:Script>
      <mx:VBox width="300" height="300">
      <mx:Button click="showLogin();" label="Login"/>
      </mx:VBox>
      </mx:Application>
      </code>
