2 Replies Latest reply on May 20, 2015 9:45 PM by kennethl97042592
    devise is not showing up on list
    tmt1310
      I installed the software last night and downloaded a book from the public libary.  I could see the down on digital editions.  I just purchased the new simple touch nook.  I plugged in the nook and it did not show up under the bookshelve as an available devise.  Is it because this nook is so new to the market.  Please help.  I'm technology challeged. thank you
        • 1. Re: devise is not showing up on list
          Level 4
          Nooks are not new to the market, so that's not the issue.  It's technology -
          your favorite subject - that needs adjustment.
          When you buy a Nook, you need to register it with B&N before you try to use
          it.  When you set up an account with B&N, your Nook will be updated with the
          latest software and a small registration file, which ADE uses when it tries
          to access it and link it up.
          Also, when you downloaded ADE, you should have done that from the Adobe
          website.  You would have set up an account with Adobe as well, and Adobe
          will authorize your copy of ADE for installation on your computer.
          You may not see anything displayed that will tell you what's going on for
          either of these setups, or you will see some technical mumbo-jumbo that
          tells you it's working.  In either case, that's the sequence you need to
          use.
          Next, you should follow a particular sequence to make sure that the two
          technologies talk to each other.  You need to turn on and plug your Nook
          into your computer first.  You can do that before you turn the computer on -
          or wait until it has started up.  When complete, your Nook should appear as
          a disk drive in your computer's list of devices.  For a Windows PC, you can
          display this by using Windows Explorer (not Internet Explorer) to display
          all the devices, or by going from the START bar to My Computer, where you
          will see a Removable Storage device called 'Nook'.  You're halfway there
          now.  The computer recognizes the Nook and has that information available
          for ADE.  The Nook will display a message also, saying it's connected to
          your computer.
          Now start ADE.  As ADE starts up, it looks on your computer for any
          removable disk drives, and queries them.  If it finds a Nook that it
          supports, it will attach the Nook to ADE.  As it does so, ADE will figure
          out whether the device is 'authorized' or not.  If it is, then it will
          display the Nook in the Bookshelf display in Library mode.  If there is no
          registration file, ADE will ask you whether you want to authorize the Nook
          to ADE, and you can say 'yes'.
          As far as library books are concerned, some of them have publisher rights
          assigned that are more restrictive than others.  A publisher can choose to
          permit you to download an ebook for one device only, or for many.  For one,
          you'll have to read the ebook on your computer.  For many, you can download
          it to your Nook.  Be aware of this restriction in case you have a
          problem copying the library ebook to your Nook, once it's talking with ADE.
          When you finish transferring ebooks from ADE, you need to follow a process
          to disconnect.  First, disconnect the reader logically from ADE and your
          computer by 'ejecting' it.  You can do this from My Computer by
          right-clicking on the device, and picking 'Eject' from the drop-down menu.
          Or, you can go to the START bar in the lower right hand portion, and you'll
          see a 'Safely Remove Device' icon, which will disconnect the Nook.  However,
          the terminology that this icon displays is pure technical.  Just trust it -
          you'll be fine.  After you've ejected the device, your Nook should display a
          message saying that it's updating for new content.  When that message is
          done, you can unplug the Nook, and then shut down ADE on your computer.
          There's more - of course - but you should be able to get started from this
          stuff.  I hope it helps!
          • 2. Re: devise is not showing up on list
            kennethl97042592
            These are good step-by-step instructions.  Unfortunately for me, they do not work.  I registered my Nook. I set up ADE 4.0 on Windows 7. I wanted to install it on Windows XP, but apparently that can't be done.  I plugged in the device and started ADE.  It does not show the device and did not give me a chance to authorize it. The computer recognizes the device. Now what? Thanks.
