2 Replies Latest reply on Jun 11, 2011 12:28 AM by Zomaxx
    Insert dynamic text fields between two static text
    Zomaxx Level 1
      Hi Forum Members,
      I 'd like to insert a dynamic text field (the costumer will fill in) between two static (fix) text.I know how to make the text field to increase or decrease the size of the fonts OR make the field wider as I type into it,,but my problem is how to choose the width of this dynamic text field that not to leave too much spaces after the following static text, I'd like to find a solution how make ther form working like in a Word file, when you type (insert text), the following words move away automaticly...Is it possible iwith PDF too..???
        • 1. Re: Insert dynamic text fields between two static text
          Srini Dhulipalla Level 5
          You can achieve this by using the Floating fields inside the static text.
          To test this, place a Text (not a Text Field) control on the form and enter some static text.
          Then place the cursor inside the static text ( by double click inside the Text) and then choose Insert menu-> Floating field.
          The floating field will be placed where the cursor is highlighted. It will be like a Text Field inside the Text.
          You can assign the value at run time to this field, so the static text will re-align to fit the value at runtime.
          Srini
          • 2. Re: Insert dynamic text fields between two static text
            Zomaxx Level 1
            Hi Srini,
            Thank you your reply, help and time answering, that's working fine!
            May I ask something new concerning to the floating area?
            Is there a possibilty to type (edit) into the floating text field are directly?
            Best regards
            Nyari Zoltan
