0 Replies Latest reply on Jun 10, 2011 12:54 AM by alveiz
    Why is this error happening?
    alveiz
      Hello,
      I've noticed that Flash Catalyst CS5.5 is much more bugged than the previous version of the program.
      We have been working for a long time now (more than 6 months) on an interface design for a website. We're a workgroup and a developer uses Builder to complete the project since I have no idea on programming.
      Problem comes when he started working on the library: Catalyst has significantly slowed down and has started crashing without any reports of "Out of Memory error".
      When crashing, it creates a txt called hs_err_pid3444. We think it's a report on the program errors and we are very disappointed with this. I hope you can (in any way) help us. Thanks in advance.
      hs_err_pid3444 contains this:
      # A fatal error has been detected by the Java Runtime Environment:
      #  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x743cb32e, pid=3444, tid=3448
      # JRE version: 6.0_16-b01
      # Java VM: Java HotSpot(TM) Client VM (14.2-b01 mixed mode windows-x86 )
      # Problematic frame:
      # C  [adbeapecore.dll+0xb32e]
      # If you would like to submit a bug report, please visit:
      #   http://java.sun.com/webapps/bugreport/crash.jsp
      # The crash happened outside the Java Virtual Machine in native code.
      # See problematic frame for where to report the bug.
      ---------------  T H R E A D  ---------------
      Current thread (0x02529000):  JavaThread "main" [_thread_in_native, id=3448, stack(0x00090000,0x00190000)]
      siginfo: ExceptionCode=0xc0000005, reading address 0x00000048
      Registers:
      EAX=0x00000000, EBX=0x000203b6, ECX=0x75312dd9, EDX=0x00000000
      ESP=0x0018efb4, EBP=0x0018efe0, ESI=0x00000000, EDI=0x01d19038
      EIP=0x743cb32e, EFLAGS=0x00010246
      Top of Stack: (sp=0x0018efb4)
      0x0018efb4:   01d19038 00000201 01640301 512477b0
      0x0018efc4:   0018efd4 778ae67f 512477b0 fffffffe
      0x0018efd4:   0018f028 7560d9e1 0018effc 0018f000
      0x0018efe4:   743c5be7 00000201 00000001 01640346
      0x0018eff4:   00000201 01d19028 01640346 0018f050
      0x0018f004:   743cb651 00000201 00000001 01640346
      0x0018f014:   0018f07c 01d19028 743c7ea3 00000000
      0x0018f024:   00000000 0000c057 00000000 00000000
      Instructions: (pc=0x743cb32e)
      0x743cb31e:   3d 74 eb 09 53 ff 15 20 22 3d 74 33 f6 8b 47 48
      0x743cb32e:   8b 40 48 c1 e8 03 f6 d0 a8 01 74 07 53 ff 15 84
      Stack: [0x00090000,0x00190000],  sp=0x0018efb4,  free space=1019k
      Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
      C  [adbeapecore.dll+0x5be7]
      C  [adbeapecore.dll+0xb651]
      C  [adbeapecore.dll+0x7f02]
      C  [USER32.dll+0x16238]
      C  [USER32.dll+0x168ea]
      C  [USER32.dll+0x20ab0]
      C  [USER32.dll+0x27b0f]
      C  [EmbeddedPlayerJNILib.dll+0x24b2]
      C  [USER32.dll+0x17d31]
      C  [USER32.dll+0x17dfa]
      C  [swt-win32-3448.dll+0x35be]
      J  org.eclipse.swt.internal.win32.OS.DispatchMessageW(Lorg/eclipse/swt/internal/win32/MSG;)I
      J  org.eclipse.swt.widgets.Display.readAndDispatch()Z
      J  org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptio nHandler;Lorg/eclipse/swt/widgets/Display;)V
      j  org.eclipse.ui.internal.Workbench.runUI()I+393
      j  org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
      j  org.eclipse.ui.internal.Workbench$5.run()V+23
      j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databindin g/observable/Realm;Ljava/lang/Runnable;)V+12
      j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display; Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
      j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/ecl ipse/ui/application/WorkbenchAdvisor;)I+2
      j  com.adobe.thermo.application.ThermoApplication.start(Lorg/eclipse/equinox/app/IApplicatio nContext;)Ljava/lang/Object;+291
      j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Objec t;+135
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Ob ject;)Ljava/lang/Object;+103
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Lja va/lang/Object;+29
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object; +149
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnabl e;)Ljava/lang/Object;+183
      v  ~StubRoutines::call_stub
      V  [jvm.dll+0xecf9c]
      V  [jvm.dll+0x1741e1]
      V  [jvm.dll+0xed01d]
      V  [jvm.dll+0x18e66b]
      V  [jvm.dll+0x18ee76]
      V  [jvm.dll+0x117bf3]
      C  [java.dll+0x714f]
      j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/l ang/Object;+87
      j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Lja va/lang/Object;+6
      j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+ 161
      j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+21 1
      j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+114
      j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
      V  [jvm.dll+0xecf9c]
      V  [jvm.dll+0xed01d]
      V  [jvm.dll+0xf5e2f]
      V  [jvm.dll+0xf7b04]
      C  [eclipse_1114.dll+0x5196]
      C  [eclipse_1114.dll+0x4721]
      C  [eclipse_1114.dll+0x152c]
      Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
      j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object; [Ljava/lang/Object;)Ljava/lang/Object;+0
      ---------------  P R O C E S S  ---------------
      Java Threads: ( => current thread )
        0x35373c00 JavaThread "Thread-146" [_thread_in_native, id=2864, stack(0x4d2d0000,0x4d3d0000)]
        0x35377400 JavaThread "Worker-2" [_thread_blocked, id=3336, stack(0x3a200000,0x3a300000)]
        0x35377800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=2620, stack(0x405f0000,0x406f0000)]
        0x35376c00 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3928, stack(0x40070000,0x40170000)]
        0x35373400 JavaThread "Thread-7" [_thread_blocked, id=744, stack(0x3a6c0000,0x3a7c0000)]
        0x36a12000 JavaThread "Thread-2" [_thread_blocked, id=2844, stack(0x39310000,0x39410000)]
        0x369b5c00 JavaThread "Worker-1" [_thread_blocked, id=3152, stack(0x38820000,0x38920000)]
        0x369b5400 JavaThread "Thread-1" [_thread_in_native, id=3344, stack(0x38720000,0x38820000)]
        0x352cbc00 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=1888, stack(0x35c30000,0x35d30000)]
        0x352cb400 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=1872, stack(0x35b30000,0x35c30000)]
        0x02617800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=1788, stack(0x34f70000,0x35070000)]
        0x02603800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=588, stack(0x34e30000,0x34f30000)]
        0x02603400 JavaThread "Attach Listener" daemon [_thread_blocked, id=848, stack(0x34cf0000,0x34df0000)]
        0x02600c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1904, stack(0x34bb0000,0x34cb0000)]
        0x025c6400 JavaThread "Finalizer" daemon [_thread_blocked, id=2008, stack(0x34ab0000,0x34bb0000)]
        0x025c5000 JavaThread "Reference Handler" daemon [_thread_blocked, id=1912, stack(0x349b0000,0x34ab0000)]
      =>0x02529000 JavaThread "main" [_thread_in_native, id=3448, stack(0x00090000,0x00190000)]
      Other Threads:
        0x025c2400 VMThread [stack: 0x348b0000,0x349b0000] [id=3268]
        0x02620c00 WatcherThread [stack: 0x350b0000,0x351b0000] [id=1400]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      def new generation   total 36288K, used 14892K [0x04630000, 0x06d90000, 0x06d90000)
        eden space 32256K,  42% used [0x04630000, 0x05375600, 0x065b0000)
        from space 4032K,  32% used [0x069a0000, 0x06ae5cf8, 0x06d90000)
        to   space 4032K,   0% used [0x065b0000, 0x065b0000, 0x069a0000)
      tenured generation   total 483968K, used 258868K [0x06d90000, 0x24630000, 0x24630000)
         the space 483968K,  53% used [0x06d90000, 0x16a5d308, 0x16a5d400, 0x24630000)
      compacting perm gen  total 65536K, used 55049K [0x24630000, 0x28630000, 0x34630000)
         the space 65536K,  83% used [0x24630000, 0x27bf2460, 0x27bf2600, 0x28630000)
      No shared spaces configured.
      Dynamic libraries:
      0x00400000 - 0x0040d000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\Adobe Flash Catalyst.exe
      0x77880000 - 0x77a00000 C:\Windows\SysWOW64\ntdll.dll
      0x755e0000 - 0x756e0000 C:\Windows\syswow64\kernel32.dll
      0x77330000 - 0x77376000 C:\Windows\syswow64\KERNELBASE.dll
      0x75d40000 - 0x75e40000 C:\Windows\syswow64\USER32.dll
      0x76300000 - 0x76390000 C:\Windows\syswow64\GDI32.dll
      0x759b0000 - 0x759ba000 C:\Windows\syswow64\LPK.dll
      0x75e40000 - 0x75edd000 C:\Windows\syswow64\USP10.dll
      0x76080000 - 0x7612c000 C:\Windows\syswow64\msvcrt.dll
      0x75910000 - 0x759b0000 C:\Windows\syswow64\ADVAPI32.dll
      0x76190000 - 0x761a9000 C:\Windows\SysWOW64\sechost.dll
      0x76560000 - 0x76650000 C:\Windows\syswow64\RPCRT4.dll
      0x753f0000 - 0x75450000 C:\Windows\syswow64\SspiCli.dll
      0x753e0000 - 0x753ec000 C:\Windows\syswow64\CRYPTBASE.dll
      0x744f0000 - 0x74574000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7600.16661_n one_ebfb56996c72aefc\COMCTL32.dll
      0x751a0000 - 0x75243000 C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_508ed732bcbc 0e5a\MSVCR90.dll
      0x76130000 - 0x76190000 C:\Windows\system32\IMM32.DLL
      0x75510000 - 0x755dc000 C:\Windows\syswow64\MSCTF.dll
      0x72000000 - 0x72014000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.100.v20080509-1800\eclipse _1114.dll
      0x75190000 - 0x75199000 C:\Windows\system32\VERSION.dll
      0x6d800000 - 0x6da8b000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\jre\bin\client\jvm.dll
      0x74ff0000 - 0x75022000 C:\Windows\system32\WINMM.dll
      0x7c340000 - 0x7c396000 C:\Windows\system32\MSVCR71.dll
      0x73ab0000 - 0x73afb000 C:\Windows\system32\apphelp.dll
      0x6d7b0000 - 0x6d7bc000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\jre\bin\verify.dll
      0x6d330000 - 0x6d34f000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\jre\bin\java.dll
      0x6d290000 - 0x6d298000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\jre\bin\hpi.dll
      0x77320000 - 0x77325000 C:\Windows\syswow64\PSAPI.DLL
      0x6d7f0000 - 0x6d7ff000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\jre\bin\zip.dll
      0x750d0000 - 0x750e6000 C:\Windows\system32\CRYPTSP.dll
      0x75090000 - 0x750cb000 C:\Windows\system32\rsaenh.dll
      0x739e0000 - 0x739f7000 C:\Windows\system32\USERENV.dll
      0x739d0000 - 0x739db000 C:\Windows\system32\profapi.dll
      0x6d610000 - 0x6d623000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\jre\bin\net.dll
      0x76390000 - 0x763c5000 C:\Windows\syswow64\WS2_32.dll
      0x75b70000 - 0x75b76000 C:\Windows\syswow64\NSI.dll
      0x73c50000 - 0x73c8c000 C:\Windows\system32\mswsock.dll
      0x73b60000 - 0x73b66000 C:\Windows\System32\wship6.dll
      0x73c90000 - 0x73ca0000 C:\Windows\system32\NLAapi.dll
      0x73c00000 - 0x73c44000 C:\Windows\system32\DNSAPI.dll
      0x73bf0000 - 0x73bf8000 C:\Windows\System32\winrnr.dll
      0x73be0000 - 0x73bf0000 C:\Windows\system32\napinsp.dll
      0x73bc0000 - 0x73bd2000 C:\Windows\system32\pnrpnsp.dll
      0x74d40000 - 0x74d45000 C:\Windows\System32\wshtcpip.dll
      0x752f0000 - 0x7530c000 C:\Windows\system32\IPHLPAPI.DLL
      0x752e0000 - 0x752e7000 C:\Windows\system32\WINNSI.DLL
      0x73b70000 - 0x73b76000 C:\Windows\system32\rasadhlp.dll
      0x73b80000 - 0x73bb8000 C:\Windows\System32\fwpuclnt.dll
      0x6d630000 - 0x6d639000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\jre\bin\nio.dll
      0x35940000 - 0x35995000 C:\Users\Alvaro\Application Data\Adobe\Flash Catalyst CS5.5\configuration\org.eclipse.osgi\bundles\208\1\.cp\swt-win32-3448.dll
      0x763d0000 - 0x7652c000 C:\Windows\syswow64\ole32.dll
      0x759c0000 - 0x75a4f000 C:\Windows\syswow64\OLEAUT32.dll
      0x772a0000 - 0x7731b000 C:\Windows\syswow64\comdlg32.dll
      0x762a0000 - 0x762f7000 C:\Windows\syswow64\SHLWAPI.dll
      0x73540000 - 0x736de000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16661_no ne_420fe3fa2b8113bd\COMCTL32.dll
      0x76650000 - 0x77299000 C:\Windows\syswow64\SHELL32.dll
      0x77380000 - 0x77475000 C:\Windows\syswow64\WININET.dll
      0x75c00000 - 0x75d36000 C:\Windows\syswow64\urlmon.dll
      0x75a50000 - 0x75b6c000 C:\Windows\syswow64\CRYPT32.dll
      0x76550000 - 0x7655c000 C:\Windows\syswow64\MSASN1.dll
      0x75710000 - 0x7590a000 C:\Windows\syswow64\iertutil.dll
      0x736e0000 - 0x73760000 C:\Windows\system32\uxtheme.dll
      0x74980000 - 0x74993000 C:\Windows\system32\dwmapi.dll
      0x005a0000 - 0x005a8000 C:\Users\Alvaro\Application Data\Adobe\Flash Catalyst CS5.5\configuration\org.eclipse.osgi\bundles\95\1\.cp\os\win32\x86\localfile_1_0_0.dll
      0x37a00000 - 0x37a41000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\plugins\com.adobe.flexide.nativelibs_1.5.0.308731\os\win32\x86\BridgeTalk.dll
      0x74300000 - 0x7436a000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\plugins\com.adobe.flexide.nativelibs_1.5.0.308731\libs\adobe_caps.dll
      0x75ee0000 - 0x7607d000 C:\Windows\syswow64\SETUPAPI.dll
      0x756e0000 - 0x75707000 C:\Windows\syswow64\CFGMGR32.dll
      0x76530000 - 0x76542000 C:\Windows\syswow64\DEVOBJ.dll
      0x761b0000 - 0x76233000 C:\Windows\syswow64\CLBCatQ.DLL
      0x6f4d0000 - 0x6f5c5000 C:\Windows\system32\propsys.dll
      0x74fc0000 - 0x74fe1000 C:\Windows\system32\ntmarta.dll
      0x75bb0000 - 0x75bf5000 C:\Windows\syswow64\WLDAP32.dll
      0x35560000 - 0x3556b000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\plugins\com.adobe.flexide.amt_1.5.0.308731\os\win32\x86\amt_win_jnilib.dll
      0x75250000 - 0x752de000 C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_508ed732bcbc 0e5a\MSVCP90.dll
      0x6ebd0000 - 0x6ecc0000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\plugins\com.adobe.flexide.amt_1.5.0.308731\os\win32\x86\amtlib.dll
      0x38920000 - 0x389d7000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\plugins\com.adobe.flexbuilder.utils.osnative_1.5.0.308731\os\win32\x86\JNIToNativeB ridge.dll
      0x6eab0000 - 0x6ebc5000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\plugins\com.adobe.flexide.amt_1.5.0.308731\os\win32\x86\amtservices.dll
      0x6f360000 - 0x6f3b8000 C:\Windows\system32\WINHTTP.dll
      0x6ea40000 - 0x6ea8f000 C:\Windows\system32\webio.dll
      0x37a50000 - 0x37a64000 C:\Users\Alvaro\Application Data\Adobe\Flash Catalyst CS5.5\configuration\org.eclipse.osgi\bundles\208\1\.cp\swt-gdip-win32-3448.dll
      0x749c0000 - 0x74b50000 C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7600.16385_none_72fc7 cbf861225ca\gdiplus.dll
      0x74020000 - 0x7411b000 C:\Windows\system32\WindowsCodecs.dll
      0x723e0000 - 0x7244a000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\plugins\com.adobe.flexide.amt_1.5.0.308731\os\win32\x86\adobe_caps.dll
      0x38ae0000 - 0x38b08000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\plugins\com.adobe.flexide.amt_1.5.0.308731\os\win32\x86\asneu.dll
      0x6f3f0000 - 0x6f44c000 C:\Windows\system32\wbemcomn.dll
      0x74f40000 - 0x74f4e000 C:\Windows\system32\RpcRtRemote.dll
      0x399e0000 - 0x39a76000 C:\Windows\system32\wbem\fastprox.dll
      0x74da0000 - 0x74db8000 C:\Windows\system32\NTDSAPI.dll
      0x74f50000 - 0x74f5d000 C:\Windows\system32\dhcpcsvc6.DLL
      0x74d50000 - 0x74d62000 C:\Windows\system32\dhcpcsvc.DLL
      0x73cd0000 - 0x73cd8000 C:\Windows\system32\credssp.dll
      0x6d170000 - 0x6d202000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\plugins\com.adobe.flexide.amt_1.5.0.308731\os\win32\x86\updaternotifications.dll
      0x73b40000 - 0x73b51000 C:\Windows\system32\NETAPI32.dll
      0x73b30000 - 0x73b39000 C:\Windows\system32\netutils.dll
      0x73b10000 - 0x73b29000 C:\Windows\system32\srvcli.dll
      0x73b00000 - 0x73b0f000 C:\Windows\system32\wkscli.dll
      0x74f00000 - 0x74f05000 C:\Windows\system32\msimg32.dll
      0x74be0000 - 0x74be9000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\plugins\com.adobe.flexide.embeddedplayer_1.5.0.308731\os\win32\x86\adbeape.dll
      0x392d0000 - 0x392ef000 C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\plugins\com.adobe.flexide.embeddedplayer_1.5.0.308731\os\win32\x86\EmbeddedPlayerJN ILib.dll
      0x743c0000 - 0x743df000 C:\Program Files (x86)\Common Files\Adobe\APE\3.2\adbeapecore.dll
      0x3bd60000 - 0x3bd77000 C:\Users\Alvaro\AppData\Roaming\Dropbox\bin\DropboxExt.14.dll
      0x6d000000 - 0x6d0eb000 C:\Windows\system32\dbghelp.dll
      0x7c3a0000 - 0x7c41b000 C:\Users\Alvaro\AppData\Roaming\Dropbox\bin\MSVCP71.dll
      0x6e430000 - 0x6e461000 C:\Windows\system32\EhStorShell.dll
      0x661c0000 - 0x663dd000 C:\PROGRA~2\MICROS~1\Office12\GR469A~1.DLL
      0x68ef0000 - 0x68fe1000 C:\PROGRA~2\MICROS~1\Office12\GrooveUtil.DLL
      0x6cf60000 - 0x6cffb000 C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_d08a205e442d b5b5\MSVCR80.dll
      0x68ff0000 - 0x68ff7000 C:\PROGRA~2\MICROS~1\Office12\GrooveNew.DLL
      0x742e0000 - 0x742fb000 C:\Windows\WinSxS\x86_microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d1c738ec4357 8ea1\ATL80.DLL
      0x6f2e0000 - 0x6f34f000 C:\Windows\system32\ntshrui.dll
      0x74280000 - 0x7428b000 C:\Windows\system32\cscapi.dll
      0x74270000 - 0x7427a000 C:\Windows\system32\slc.dll
      0x6c6a0000 - 0x6cf59000 C:\Program Files (x86)\Common Files\Adobe\APE\3.2\adbeapeengine.dll
      0x74c50000 - 0x74c8c000 C:\Windows\system32\OLEACC.dll
      0x6c460000 - 0x6c6a0000 C:\Windows\system32\msi.dll
      0x6f450000 - 0x6f4c9000 C:\Windows\system32\mscms.dll
      0x6e9c0000 - 0x6ea32000 C:\Windows\system32\DSOUND.dll
      0x6e990000 - 0x6e9b5000 C:\Windows\system32\POWRPROF.dll
      0x74210000 - 0x74261000 C:\Windows\system32\WINSPOOL.DRV
      0x6e960000 - 0x6e98e000 C:\Windows\system32\mlang.dll
      0x6c420000 - 0x6c458000 C:\Windows\system32\icm32.dll
      0x74dc0000 - 0x74dc8000 C:\Windows\system32\Secur32.dll
      0x6e920000 - 0x6e95a000 C:\Windows\SysWOW64\schannel.dll
      0x6e8e0000 - 0x6e919000 C:\Windows\system32\MMDevAPI.DLL
      0x6e810000 - 0x6e840000 C:\Windows\system32\wdmaud.drv
      0x6f350000 - 0x6f354000 C:\Windows\system32\ksuser.dll
      0x6e8d0000 - 0x6e8d7000 C:\Windows\system32\AVRT.dll
      VM Arguments:
      jvm_args: -Xms512m -Xmx512m -XX:MaxPermSize=256m -XX:PermSize=64m
      java_command: <unknown>
      Launcher Type: generic
      Environment Variables:
      PATH=C:/Program Files (x86)/Adobe/Adobe Flash Catalyst CS5.5/jre/bin/client;C:/Program Files (x86)/Adobe/Adobe Flash Catalyst CS5.5/jre/bin;C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\Window sPowerShell\v1.0\;C:\Program Files\TortoiseSVN\bin
      USERNAME=Alvaro
      OS=Windows_NT
      PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 15 Stepping 11, GenuineIntel
      ---------------  S Y S T E M  ---------------
      OS: Windows 7 Build 7600
      CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 15 stepping 11, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
      Memory: 4k page, physical 4111668k(1899496k free), swap 4194303k(4194303k free)
      vm_info: Java HotSpot(TM) Client VM (14.2-b01) for windows-x86 JRE (1.6.0_16-b01), built on Jul 31 2009 11:26:58 by "java_re" with MS VC++ 7.1
      time: Fri Jun 10 09:29:13 2011
      elapsed time: 5086 seconds
