4 Replies Latest reply on Jun 20, 2011 8:36 AM by JohnDevlon
    [CS5][JS] Building a dialog window using a GUI?
    JohnDevlon Level 1
      What I would like to know: is there a tool available in which a dialog window can be build using a graphic user interface? Can this window be loaded into a indesign javascript? Or is the only way still to hardcode the dialog window into the script.
      The reason i'm asking is because:
      - It isn't easy to build a menu when you can't view the window without running the script
      - In most cases the number of code lines for display the dialog window is larger than the number of lines for processing the data
      Kind regards
      John
