4 Replies Latest reply on Jun 10, 2011 11:31 AM by Daniel Pride
    ArrayCollection GetItemAt
    Daniel Pride Level 1
      I want to return the index of an item in an ArrayCollection to set the selected index property of a combo box
      [Bindable] public var times:ArrayCollection = new ArrayCollection(
                      [ {label:"1:00", data:"01:00:00"}, {label:"1:15", data:"01:15:00"},{label:"1:30", data:"01:30:00"} ]);
      The Following does not work.
      var item:Object = new Object();
      item = {data:"01:15:00"};
      this.RepairBySelected = times.getItemIndex(item);
      Given a string value of "01:15:00"
      How do I return the value of 1 from the times ArrayCollection (the index of that value)?
      Dan
        • 1. Re: ArrayCollection GetItemAt
          pauland Level 4
          Dan
          You're going to have to search for it. Your code example can't work for two reasons:
          1) your item Object is not in the array collection - it refers to a differrent object altogether
          2) your item Object was only partof the data held in the Array collection entries (but it makes no differrence due to the first point;
          // find entry that has the same time string as item
          for (var i:int=0;  i< times.length; i++){
               if ( item.data == getItemAt(i).data){
                    return i;
          • 2. Re: ArrayCollection GetItemAt
            Give the ArrayCollection
            Give me a use of GetitemIndex that would return the index of the second item listed. (i.e. 1)
            Dan
            • 3. Re: ArrayCollection GetItemAt
              pauland Level 4
              Dan
              Yes, Sir!
              public var _entry:Object = {label:"1:15", data:"01:15:00"};
              public var _entry2:Object = {label:"1:15", data:"01:15:00"};
              [Bindable] public var times:ArrayCollection = new ArrayCollection([ {label:"1:00", data:"01:00:00"}, _entry ,{label:"1:30", data:"01:30:00"} ]);
              trace(""+times.getItemIndex(_entry)+",  "+times.getItemIndex(_entry2));
              • 4. Re: ArrayCollection GetItemAt
                Thanks !
                Made you work for your chit that time
