5 Replies Latest reply on Jun 13, 2011 10:29 AM by Flex harUI
    Modify XML attribute
    Zolotoj Level 3
      I am trying to use the following to change attribute's value:
      trace(XML(tree.dataProvider)..menu.(@menuid == 12).@description2);
      XML(tree.dataProvider)..menu.(@menuid ==12).@description2 = htmlText;
      Both traces are the same, empty in my case. Any idea?
        • 1. Re: Modify XML attribute
          Flex harUI Adobe Employee
          There might be issues with trying to set a value on more than one item.
          Each query is an XMLList and could have more than one item in it.
          Try something like:
              XML(tree.dataProvider)..menu.(@menuid ==12)[0].@description2 = htmlText;
          • 2. Re: Modify XML attribute
            Zolotoj Level 3
            Does not look like it's helping.
            NewNode = XML(tree.dataProvider)..menu.(@menuid == 12)[0];
            NewNode looks like this:
            <menu name="General  Regulations" menuid="12" description2="">
              <menu name="Rule Gr-1" menuid="13" description2=""/>
              <menu name="Rule Gr-2" menuid="14" parentid="12" description2=""/>
              <menu name="Rule Gr-3" menuid="15" parentid="12" description2=""/>
              <menu name="Rule Gr-4" menuid="20" parentid="12" description2=""/>
            </menu>
            and
            XML(tree.dataProvider)..menu.(@menuid == 12)[0].@description2 = htmlText;
            has no effect.
            • 3. Re: Modify XML attribute
              I assume htmlText is a simple string?  I'm not sure you can put angle
              brackets in an attribute without escaping it.
              Post a 20-line test case if you want us to take a closer look.
              • 4. Re: Modify XML attribute
                Zolotoj Level 3
                I was able to narrow down my code:
                NewNode = XMLList(tree.dataProvider)..menu.(@menuid == 12);
                NewNode.@description2 = htmlText;
                trace(NewNode.@description2); // shows data
                XMLList(tree.dataProvider)..menu.(@menuid == 12).@description2 = htmlText;
                trace(XMLList(tree.dataProvider)..menu.(@menuid == 12).@description2); // still empty.
                What am I doing wrong here?
                • 5. Re: Modify XML attribute
                  In the first case, you are storing the XMLList of the query and working with
                  the elements in that XMLList.  In the second, you are running a second
                  query.  Seems like it should work anyway, but there must be some subtle
                  reason why it doesn't.
