1 Reply Latest reply on Jun 11, 2011 11:24 PM by Flex harUI
    Modules having sub-modules dont load in the right order
    VeenaChezhian Level 1
      Hey,
      I have a main application which loads a module. The module has two sub-modules in it. I had the module's creationpolicy set to "all", so that all its sub-modules load at application startup.
      I have a creationComplete handler created for the main module ( which has 2 sub-modules ) which sends a global event to the main application about its creation complete phase. I see that the creationComplete of the main module gets called even before it loaded its sub-modules. This case happens only with my release build. When i run the same code in Flash Builder I can easily get it work right.
      Any light in this issue will be of great help.
      Here is the code snippet which may be helpful
      <mx:Module
      xmlns:parsley="http://www.spicefactory.org/parsley"
      xmlns:mx="http://www.adobe.com/2006/mxml"
      width="100%"
      height="100%"
      creationComplete="module1_creationCompleteHandler(event)"
      creationPolicy="all"
      <mx:Script>
      <![CDATA[
      private function module1_creationCompleteHandler(event:Event):void
      var simEvent:SIMActivityEvent = new SIMActivityEvent(SIMActivityEvent.SIM_ACTIVITY_MODULE_LOAD_COMPLETE);
      simEvent.message = _resourceManager.getString( 'splashScreen.manageModuleLoaded');
      dispatchEvent(simEvent);
      </mx:Script>
      <mx:ViewStack
      id="viewStack"
      width="100%" height="100%"
      paddingBottom="5" paddingRight="5" paddingLeft="5"
      change="handleViewChanged()"
      <mx:ModuleLoader
      url="Module1.swf"
      label="{_resourceManager.getString( 'navigation.appliances')}"
      width="100%"
      height="100%"
      <mx:ModuleLoader
      url="Module2.swf"
      label="{_resourceManager.getString( 'navigation.agents')}"
      width="100%"
      height="100%"
      </mx:ViewStack>
      </mx:Module>
      Btw, the module is a separate project and I am using RSL all over the place. I am not sure if this matters.
