3 Replies Latest reply on Mar 4, 2013 3:05 AM by ds garg
    How to open pdf file in Air Application?
    muikyo
      Hi, everybody
           I trying to open file pdf from my macbook in Air Application, but it's didn't display anything to me.
      Please help me. I wanna know Adobe Air can open PDF File from Mac or and Window os?
      This sample code i used..
      var request:URLRequest = new URLRequest("/Users/Morn/Desktop/RD_phase3.pdf");
      var pdf = new HTMLLoader();
      pdf.x = 0;
      pdf.y = 0;
      pdf.height = stage.stageHeight;
      pdf.width = stage.stageWidth;
      pdf.load(request);
      container.addChild(pdf);
      Thanks a lot,
        • 1. Re: How to open pdf file in Air Application?
          blazejewicz Level 4
          if it didnt' display content - what happens? Is there greyed area in application visible?
          By default Air does not use OS X built-in PDF content support - you need pluggable Adobe solution installed along of AIR runtime.
          Also - you could face issue with path, be advised to use URI based "file://" protocol on OS X (it should work on Windows as well btw),
          Give it a try:
          code:
          var file:File = File.desktopDirectory.resolvePath("RD_phase3.pdf");
          if(HTMLLoader.isSupported &&
               (HTMLLoader.pdfCapability == HTMLPDFCapability.STATUS_OK) &&
               file.exists)
               // file://{URI}
               var url:String = file.url;
               pdf.load(new URLRequest(url));
          } else
               pdf.loadString("handle errors in user friendly way");
          hth,
          kind regards,
          Peter
          • 2. Re: How to open pdf file in Air Application?
            bobbyjimp
            Having basically the same issue.  A blank screen appears.  I am using an iframe to display the PDF file (or trying to)
            Windows 7 Professional
            Acrobat Pro X
            AIR 2.7
            AIR SDK 2.7
            Code:
            <script>
            function init()
              var out = document.getElementById('outDiv');
              if (air.HTMLLoader.pdfCapability ==
               air.HTMLPDFCapability.STATUS_OK)
               out.innerHTML =
                "<iframe src='pdf/newsletter.pdf' width='700' height='500'></iframe>";
              else
               out.innerHTML = "<h2>PDF capability not found</h2> <p>Error is: " + air.HTMLLoader.pdfCapability+"</p>";
            </script>
            I am receiving a 3202 error on return from HTMLLoader.pdfCapability (acrobat version too old)
            • 3. Re: How to open pdf file in Air Application?
              ds garg
              have same problem
              i am using flex 4.0, AIR 3.4 and Adobe Reader X(10.14)
              unable to load pdf file and throwing error code 3202(i.e. acrobat version too old). anybody can tell whats the actual issue.
