1 Reply Latest reply on Jun 23, 2011 1:32 PM by Heidi Williams
    Flex 4.5 and Flash Builder for php
    Zepse7en
      Hello Flex Community,
      I have a couple of questions, so i am currently working on a data driven felx web app, that uses php as the server side interpretor..
      my main question here is after doign a lot of research (and correct me if i sound like an idiot please) i would personally rather connect to my database tables using http service calls rather than the data services, I like the fact that adobe included the data services and generate classes option, but i think I would be more comfortable using the http service call for many reasons including securing it and making more customizable classes, so back to my question haha is this not the smartest of ideas?
      Also if i am making these custom classes in php and doing a lot of php work for my should i invest in "Flash Builder for PHP" i am using 4.5 premium right now and i think it is working fine but are there clear benefits to having the php version that would make it worth the $300
      Thanks for any insight
        • 1. Re: Flex 4.5 and Flash Builder for php
          Heidi Williams Level 1
          Using HTTPService directly is a fine way to go if that's what you are comfortable with. There are several benefits of doing the data services and the code gen route, but it's up to you whether they are compelling for your use case. The first benefit is strong typing on the ActionScript side and being able to easily do data binding to your UI elements. This should likely make development go more quickly for you. Another benefit is the built in support for paging and client-side data management. Those can be really helpful for large data sets and improving performance, as well as for batching up edits on the client-side instead of having to submit edits one at a time.
          If you do use the DCD features, you should not be at all restricted to the kind of PHP classes you write, so you should still be able to secure it the way you want to. Were you finding a restriction there? We'd be interested to hear what issues you encountered if you did write a custom class and we weren't able to introspect it, or you weren't able to secure it the way you wanted to...
          As for Flash Builder for PHP, some people might say the integrated debugging alone is worth the upgrade. It makes debugging the ActionScript and PHP much quicker and it's easier to track down issues. It's also helpful to have the project wizards set up the linked Flex and PHP projects for you so that it's not so manual setting up the Flex project to point to the PHP server, etc. Also, if you do go with DCD features over plain HTTPService, the introspection for the PHP classes is done via Zend Studio's code intelligence, so you have way fewer steps to building the strongly typed ActionScript value objects and services. So overall, I'd say FBPHP is about improving productivity when working with Flex and PHP together. Hope this info was helpful for your decision!
          -Heidi
