1 Reply Latest reply on Jun 13, 2011 6:46 AM by Harbs.
    How to update a library item via JS
    canpserra
      I would like to Know if it is possible to make a script to update Library items. According to Indesign Help you can use the Object Library panel to manage objects.
      Update a library object with a new item
      1. In the document window, select the item you want to add to the Library panel.
      2. In the Library panel, select the object you want to replace, and then choose Update Library Item from the Object Library panel menu.
      I was looking at ESTK Indesign object model but could not find any propertie or method about update a library item.
      Any help will be welcome.
      C. Serra
