1 Reply Latest reply on Jun 13, 2011 9:43 AM by kwythers
    anchored graphics and captions with numbered lists
    kwythers Level 1
      I'm trying to speed up the creation of captioned figures. It seems that if I create a graphics frame (for the screen shot) and a text frame (for the caption) to be used as templates (I want to use copy paste in order anchor both the screen shot and the caption in place, that ID does not let you select both frames for copy and paste unless they are "grouped". However, grouping seems to mess up the numbering used in the caption. Does anyone have some experieince with this and be willing to suggest an alternalte work flow?
      Thanks in advance
        • 1. Re: anchored graphics and captions with numbered lists
          kwythers Level 1
          Additional information. If I paste the graphics frame first (thereby anchoring it), and then paste the text frame for the caption, the caption numbering works fine. However, I want the two to be connected so that they both flow together with the text where the first object is anchored, and ID does not let me select both objects in order to "group" them. Seems I can only "group" before the the frist object is anchored.
