4 Replies Latest reply on Jun 15, 2011 11:39 AM by yyterrwihbgd
    Problem displaying base64 encoded images in a datagrid
    yyterrwihbgd Level 1
          I have a number of thumbnail images (8K ish in length), stored in a sqlite database, encoded as base64 strings.
      I would like to retrieve these images and present them into a datagrid (along with some other information from the DB)
      The retrieval of information from the database works, but I cannot quite "see" how to connect the decoded images (result) from the database to the datagrid, to display the images.
      Below is some code, where I show (to simplify things) a simple DGrid and want to use the dataprovider to point to the select statement from the DB
      Any details to show how I need to change this code would be greatly appreciated:-)
            <mx:DataGrid id="dg2" dataProvider="{dp2}">
              <mx:columns>
                <mx:DataGridColumn headerText="Image"  dataField="image"  width="150"/>
              </mx:columns>
            </mx:DataGrid>
      The code to generate the dp2 information is as follows.
      The result2 array is populated as expected and ldr appears to be populated, but imageBMap and (therefore) dp2 are null:-(
              sql2.text = "SELECT image FROM  bookMarks;";
              sql2.execute();
              var result2:SQLResult = sql2.getResult();
              var data2:Array = result2.data;
              var base64Dec:Base64Decoder;
              var byteArr:ByteArray;
              var bmap:Bitmap;
              var ldr:Loader = new Loader();
              base64Dec = new Base64Decoder();
              if(result2.data != null)
                var numRows:int = result2.data.length;
                for(var i:int = 0; i < numRows; i++)
                  for(var columnName:String in result2.data[i])
                    if(columnName == "image") // Normally there will be more than 1 column in the select, hence this check
                      base64Dec.decode(result2.data[i][columnName]);
                      byteArr = base64Dec.toByteArray();
                      ldr.contentLoaderInfo.addEventListener(Event.COMPLETE, loaderComplete);
                      ldr.loadBytes(byteArr);
              var imageBMap:Bitmap = Bitmap(ldr.content);
              dp2 = ArrayCollection(imageBMap);
            private function loaderComplete(event:Event):void
              var loaderInfo:LoaderInfo = LoaderInfo(event.target);
              var bitmapData:BitmapData = new BitmapData(loaderInfo.width, loaderInfo.height, false, 0xFFFFFF);
              bitmapData.draw(loaderInfo.loader);
