2 Replies Latest reply on Mar 22, 2009 9:41 AM by Dan Bracuk
    Webservice invocation
    shafiur
      Need help in invoking these webservices..
      There are two webservices that I am trying to invoke one after the other:-
      1) first web service "setupwebsession" sets a session. Here I have setup the session.webuserUI to a component.
      2) second service tries to get a profile but displays an error
      Here is the webservice consuming:-
      <cfinvoke webservice=" http://localhost:8050/WebServices.cfc?wsdl"
      method="setUpWebUserSession"
      returnVariable="soo">
      <cfinvokeargument name="userName" value="shafiatcc@gmail.com">
      <cfinvokeargument name="applicationToLogIn" value="atccWeb">
      </cfinvoke>
      <cfoutput> #soo# </cfoutput>
      <cfdump var="#Session.SessionID#">
      method="getProfileHTML" returnvariable="profilehtml">
      </cfinvoke>
      <cfoutput>#getProfileHTML#</cfoutput>
      I am trying to consume both these webservices but it displays a following error.
      Cannot perform web service invocation getProfileHTML.
      The fault returned when invoking the web service operation is:
      AxisFault
      faultCode: { http://schemas.xmlsoap.org/soap/envelope/}Server.userException
      faultSubcode:
      faultString:
      [line 1, column 8] [--Catch Data--]
      type: Application
      tagname: CFOUTPUT
      template: C:/jboss-eap-4.3/jboss-as/server/atcc/tmp/deploy/tmp48291CTiWebServicesAPI.ear-contents/C TiWebServicesAPI-exp.war/CTiWebServicesAPI.cfc
      Line: 75; Column: 3
      ErrorCode:
      message: session.WebUserUI.getWebProfileHTML() doesn't exist.
      detail: Error at line 1, column 8
      faultActor:
      faultNode:
      faultDetail:
      { http://xml.apache.org/axis/}hostname:124426-SECOM1
      The error occurred in C:\ColdFusion8\wwwroot\selfprojects\webservices1.cfm: line 10
      8 : <cfdump var="#Session.SessionID#">
      9 : <cfinvoke webservice=" http://localhost:8050/webervices.cfc?wsdl"
      10 : method="getProfileHTML" returnvariable="profilehtml">
      11 : </cfinvoke>
      12 : <cfoutput>#getProfileHTML#</cfoutput>
      Resources:
      Check the ColdFusion documentation to verify that you are using the correct syntax.
      Search the Knowledge Base to find a solution to your problem.
      Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
      Remote Address 127.0.0.1
      Referrer http://localhost:8500/selfprojects/
      Date/Time 19-Mar-09 04:27 PM
      Stack Trace (click to expand)
      at cfwebservices12ecfm1268558828.runPage(C:\ColdFusion8\wwwroot\selfprojects\webservices1.cf m:10)
      coldfusion.xml.rpc.ServiceProxy$ServiceInvocationException: Cannot perform web service invocation getProfileHTML.
      at coldfusion.xml.rpc.ServiceProxy.invokeImpl(ServiceProxy.java:230)
      at coldfusion.xml.rpc.ServiceProxy.invoke(ServiceProxy.java:143)
      at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2222)
      at coldfusion.tagext.lang.InvokeTag.doEndTag(InvokeTag.java:417)
      at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:196)
      at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:370)
      at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
      at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:279)
      at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)
      at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
      at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
      at coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:27)
      at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
      at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
      at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
      at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
      at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
      at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
      at coldfusion.CfmServlet.service(CfmServlet.java:175)
      at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
      at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
      at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 )
      at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
      at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
      at jrun.servlet.FilterChain.service(FilterChain.java:101)
      at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
      at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
      at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)
      at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
      at jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
      at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)
      at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
      at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)
      at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
