1. Re: HDV Captures with no Preview
John T Smith Jun 13, 2011 3:57 PM (in response to Spoot51)HDV has never been visable while transferring from tape to computer
Use this for HD capture http://strony.aster.pl/paviko/hdvsplit.htm
2. Re: HDV Captures with no Preview
Spoot51 Jun 13, 2011 4:17 PM (in response to John T Smith)Thanks for the link. I guess I'll have to try it.
I would have sworn that it was possible to 'view' an HDV clip in the capture panel while simply playing the clip and setting In/Out points. I knew it is not possible to view the clip while doing the capture.
3. Re: HDV Captures with no Preview
Jon-M-Spear Jun 13, 2011 11:50 PM (in response to Spoot51)You are right! You shou d be able to preview HDV source material in the capture screen whilst you select in/out points. It's the monitoring of HDV during capture that does not happen.
Ensure that your capture mode in PP is set to HDV, not DV and, conversly, check that your camera is not set to downsample to DV, whilst PP is set to capture HDV.
4. Re: HDV Captures with no Preview
Terra_Dav Jul 1, 2011 2:23 PM (in response to Spoot51)Spoot51:
I am having the same problem capturing HDV after upgrading to CS5.5. Premiere. Did you find a solution? BTW, when capturing HDV in CS5 via a firewire you can view the video in the capture window while setting the ins and out points (as you stated). But apparently Adobe changed how the capture process works in CS5.5. or is it a bug? I would like to know. Also, when you clips are captured are they saved in the identical format when using Cs5.5 vs CS5? Since CS5 is still loaded on my machine, I plan to CS5 to capture video.
Cheers, JD
5. Re: HDV Captures with no Preview
Todd_Kopriva Jul 1, 2011 5:18 PM (in response to Terra_Dav)I think that I have a fix. I'll report back in a bit once I've tested it.
6. Re: HDV Captures with no Preview
Todd_Kopriva Jul 4, 2011 2:55 PM (in response to Todd_Kopriva)Try this:
1. Quit Premiere Pro.
2. Copy the mc_dec_mp2v.dll file from this location:
C:\Program Files\Adobe\Adobe Premiere Pro CS5.5\Plibs
... and put it here:
3. Restart Premiere Pro.
The problem appears to be that the installer isn't putting a copy of this DLL in the right place.
7. Re: HDV Captures with no Preview
Spoot51 Jul 4, 2011 7:18 PM (in response to Todd_Kopriva)Todd! Thank you, your fix worked beautifully the first time I tried it!
ADOBE!!! Sign this man up for a promotion and a raise!!
8. Re: HDV Captures with no Preview
AvKuSG Jul 5, 2011 6:11 AM (in response to Todd_Kopriva)I have the same problem. Unfortunately your recoomendation did not solve the problem.
Can you please help me.
Thanks and regards
Karl E Schmitt
9. Re: HDV Captures with no Preview
AvKuSG Jul 6, 2011 6:29 AM (in response to AvKuSG)Further to my request for help from yesterday some additional info re my PC and camera:
OS: Windows 7 64-bit, CPU: Intel Core i7 920, graphics card: NVIDIA Quadro FX580, driver version 8.17.12.7536, RAM: 6 GB DDR3, camera: Sony HDR-FX7E
All worked well with previous version of Premiere. All settings are the same as used previously.
Camera can be operated from capture panel, in and out points can be set and capture is working.
Only change: update of graphic card driver
10. Re: HDV Captures with no Preview
Spoot51 Jul 6, 2011 1:06 PM (in response to AvKuSG)If you can view the video in the "CAPTURE PANEL" in PPRO while you are setting the IN/OUT points, and "logging" clips, then the fix works. When you go back to actually "capture" the batch or clip no HDV or High Def video will be available in PPRO and it never was.
If I have misunderstood your question, I can't help.
Good luck!
11. Re: HDV Captures with no Preview
ferdinandNGC Jul 6, 2011 3:14 PM (in response to Spoot51)Todd from Adobe's solution to viewing video and sound while setting up Batch Capture works great.
SADLY I just moved from CS3 where I could view video and sound while it captured to my computer.
Now with CS5.5 you can view nothing or hear no sound.
This is a step backwards or am I missing something?
12. Re: HDV Captures with no Preview
AvKuSG Jul 6, 2011 11:48 PM (in response to Spoot51)I know that there is no picture in the capture panel during actual capture. But my problem is that there is also no picture just playing the video using the capture panel for setting in and out points.
Everything worked fine with the previous version of Premiere. The problem started after the upgrade from Creative Suite 4 Production Premium to Creative Suite 5.5 Production Premium, i.e. Premire CS5.5.
Some further info re the problem:
1) in the control panel under printers and devices the camera is shown as working proberly.
2) the camera can be operated from the capture panel for viewing the footage and audio is availble but no picture of the footage. However, the footage can be seen on the monitor of the camera.
3) In and out points can be set and clips can be captured either manually or between in and out points using the capture panel.
4) a number of fire wires have been used and all show the same result - audio Ok but no picture in the capture panel.
5) copying the mc_dec_mp2v.dll file as recommended by Todd did not solve the problem.
6) playback in the programme monitor works perfectly.
7) The recommendation as per page 82 of Adobe's Manual, i.e. "If the video image does not appear in the Capture panel, verify your device control and capture settings. Then, leaving the device on, restart Premiere Pro" was followed but did not solve the problem
Please help.
13. Re: HDV Captures with no Preview
Todd_Kopriva Sep 12, 2011 4:27 PM (in response to AvKuSG)There's a fix in the Premiere Pro CS5.5 (5.5.1) update relating to preview when capturing HDV.
After you've installed that update, let us know how it works for you.
14. Re: HDV Captures with no Preview
Ann Bens Sep 12, 2011 4:49 PM (in response to Todd_Kopriva)Long over due, but thanks anyway.
15. Re: HDV Captures with no Preview
Ann Bens Sep 13, 2011 1:13 PM (in response to Ann Bens)Installed the update and did some hdv capture.
The first time i tried it i had preview during capture.
After that no more preview during capture only during play.
If i stop the tape the screen goes black.
16. Re: HDV Captures with no Preview
ferdinandNGC Sep 13, 2011 3:00 PM (in response to Ann Bens)Ann looks like the update is not ready for Prime Time. I was just about to update but will now
wait till Adobe solves the problem.
Sadly my other computer with CS3 and the Matrox RT.X2 never had a problem and I could view the video during batch capture.
17. Re: HDV Captures with no Preview
SAFEHARBOR11 Jan 9, 2012 1:38 PM (in response to ferdinandNGC)The Matrox RT.X2 was providing the preview during capture - this was not possible in Premiere without Matrox hardware
Jeff Pulera
Safe Harbor Computers
18. Re: HDV Captures with no Preview
BGIXHUXHI Jun 1, 2012 2:10 AM (in response to ferdinandNGC)hi
i just have a question can i do real time video editing with my matrox rtx2 on premier cs5.5 ?
19. Re: HDV Captures with no Preview
SAFEHARBOR11 Jun 1, 2012 5:57 AM (in response to BGIXHUXHI)Premiere CS5 was the last supported version for Matrox RT.X2, there will be no new drivers beyond CS5. If you are currently using CS4 or older, note that with CS5, Matrox was forced to eliminate all of the Matrox GPU effects from RT.X2 due to the Adobe Mercury Playback Engine taking over the GPU.
Moving forward, please consider the Matrox MXO2 hardware line if you need capture and monitoring capabilities with CS5.5 or CS6.
Jeff Pulera
