4 Replies Latest reply on Jun 14, 2011 5:19 AM by Arul pugazh
    Object Proxies into ArrayCollections
    Arul pugazh
      1 . Retrieve data from MySQL table using PHP and echo it in XML .
      - This part is working fine and prints the data in XML form
      2 .I receive that XML and assign it as ArrayCollection . Then pass that ArrayCollection into a Component .
      - For this i have done :
      My code :
      <mx:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                      xmlns:mx="library://ns.adobe.com/flex/mx" layout="absolute" minWidth="955" minHeight="600"
                      xmlns:comp="Components.*">
          <fx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.controls.Alert;
                  import mx.events.FlexEvent;
                  import mx.rpc.events.ResultEvent;
                  [Bindable]
                  public var _myData:ArrayCollection;
                  protected function service_resultHandler(event:ResultEvent):void
                      _myData=new ArrayCollection();
                      _myData=event.result.map.location;
                  protected function maps1_creationCompleteHandler(event:FlexEvent):void
                      service.send();
          </fx:Script>
          <fx:Declarations>
              <mx:HTTPService id="service" url="map.php" result="service_resultHandler(event)" />
          </fx:Declarations>
          <comp:Maps creationComplete="maps1_creationCompleteHandler(event)"/>
      </mx:Application>
      The Error i got :
      Type Coercion failed :Cannot convert ObjectProxies into ArrayCollection
      I have previously done this type of conversion and got no errors . This is bugging me very much guys........
      Any suggestions welcome....
        • 1. Re: Object Proxies into ArrayCollections
          CleanCoder Level 2
          In your "service_resultHandler", you initialize "_myData" as a new ArrayCollection, then you immediately assign it the value of the "event.result.map.location". Instead of doing that try casting the event.result.map.location as an ArrayCollection? ("_myData = event.result.map.location as ArrayCollection")
          • 2. Re: Object Proxies into ArrayCollections
            Arul pugazh Level 1
            @CodeCleaner , Yes , i tried that also .
            But it says :
            TypeError: Error #1009: Cannot access a property or method of a null object reference.
            i.e., _myData is null ........
            Another note :
            I previously accessed a  local xml file using the same method and it worked like dream .
            I will post the map.php file i'm using :
            PHP code :
            <?PHP
            mysql_connect("localhost","root");
            mysql_select_db("location_db");
            $result=mysql_query("select id,name,address,latitude,longitude from location_table");
            echo "<?xml version=\"1.0\" ?><map>";
            while($row = mysql_fetch_assoc($result))
                echo "<location><id>" . $row["id"] . "</id>" ;
                echo "<name>" . $row["name"] . "</name>" ;
                echo "<address>" . $row["address"] . "</address>" ;
                echo "<latitude>" . $row["latitude"] . "</latitude>" ;
                echo "<longitude>" . $row["longitude"] . "</longitude></location>" ;
            echo "</map>";
            Output :
            <?xml version="1.0" ?><map><location><id>4001</id><name>Some Location</name><address>1001 W MacArthur Blvd , Santa Ana ,CA</address><latitude>33.70008360</latitude><longitude>-117.88000488</longitude></locati on><location><id>4002</id><name>Some House</name><address>7464 kipling street , Detroit ,MI</address><latitude>42.36729290</latitude><longitude>-83.08875600</longitude></locatio n></map>
            It exactly prints out what i wanted ......
            So i can't figure out where is wrong ..........
            • 3. Re: Object Proxies into ArrayCollections
              CleanCoder Level 2
              Try setting the "resultFormat" property to "xml" maybe?
              • 4. Re: Object Proxies into ArrayCollections
                Arul pugazh Level 1
                I have done the most silliest thing in the world .......
                I haven't set any Application Server for my project .
                I set that as PHP and it worked like dream......
                @CleanCoder , thank you very much for the suggestions and more importantly , your time .
