7 Replies Latest reply on Jun 15, 2011 5:59 AM by TheScarecrow
    User Draw Line
    TheScarecrow Level 1
      I am constructing a matching game where the user will draw a line between two items.  Has anyone done this or know of an example code wise that would help me.  I am not sure how to constrain the line to just between the items or how to know if the correct two items have been connected. Thanks in advance.
        • 1. Re: User Draw Line
          do you know how to draw a line using actionscript?
          • 2. Re: User Draw Line
            Yes with the lineTo.   That is what I am wanting to do .. all actionscript with the line draw.
            • 3. Re: User Draw Line
              if each of your to-be-connected objects is a movieclip, you can assign a property (eg, match) to each that stores its match.  then when your line draw from a starting movieclip is complete you can check for a mouse hittest with that movieclip's match property.
              • 4. Re: User Draw Line
                Yes .... that is my thought so each line would create its own movie clip?
                • 5. Re: User Draw Line
                  no.
                  mc1.match=mcsomething;
                  mc2.match=mcwhatever;
                  var tl:MovieClip=this;
                  for(var i:Number=0;i<mcNumber;i++){
                  tl["mc"+i].onPress=function(){
                  this.moveTo(this._x,this._y);
                  this.onEnterFrame=function(){
                  with(this){
                  lineTo(this._x,this._y);
                  tl["mc"+i].onRelease=function(){
                  delete this.onEnterFrame;
                  if(this.match.hitTest(tl._xmouse,tl._ymouse)){
                  // matched
                  } else {
                  this.clear();
                  • 6. Re: User Draw Line
                    can you explain some of that code I am not sure how that works?
                    • 7. Re: User Draw Line
                      // each mc has a match property identifying the piece to which it should be matched
                      mc0.match=mcsomething;
                      mc1.match=mcwhatever;
                      // tl references the current timeline
                      // loop through all movieclips mc0,mc1,..mc[mcNumber-1]
                      // define onPress for each movieclip to start line draw
                      // move line start to this movieclip
                      // start loop to update line as mouse is moved
                      with(this){
                      // define onRelease to stop drawing line and determine if line extends to matching mc
                      // terminate enterframe loop
                      // check for matching mc
                      // matched - do something?
                      } else {
                      // not matched - clear the line per your design specs
                      this.clear();
