7 Replies Latest reply on Jul 19, 2011 6:30 AM by leejk
    Unable To Include Files In iOS Package
    leejk Level 1
      I an using the latest release version of Flash Builder, trying to package an app for the iPad. I have an AIR application that I created to run on a desktop, and have modified it to run on the iPad. It works fine, however I cannot package the need resource files it uses, such as jpg, xml, swf, and flv files within the ipa file using Flash Builder. It seems that if I select more than 30-40 of these types of files to include, Flash Builder will not compile the ipa file without some sort of error, the most common one talks about:
      "Cannot run program "java.exe" (in directory "C\Users\lee\AppData\Local\Temp\AOT1308010984915"): CreateProcess error=206, The filename or extension is too long"
      Now I am guessing that Flash Builder is appending all of my selected files to a command line string or something somewhere, and so it can't handle that long of string on the command line. If I stick to less than 30 files, it works fine, but if I try and the 1000 or so files that I need to, it will not work.
      This app would never be in the app store, but rather on internal company iPads. The reason for so many files is the number of products the app covers, and the number of languages it supports. So yes the ipa file would be about 500Mb, but that should not be an issue, since an ipa file is basically a zipped archive. I think this is a bug though in Flash Builder; the program also becomes unresponsive when trying to access the include file list located in Project Properties -> ActionScript Build Packaging -> Apple iOS settings dialog. It make take several minutes before FB becomes responsive again when working with this number of files.
      Does anyone have any suggestions?
      thanks
        • 1. Re: Unable To Include Files In iOS Package
          Anirudh Sasikumar Adobe Employee
          There were issues regarding size and number of files of package.
          Can you confirm if this problem persists when using Flash Builder 4.5.1 as well? (If you haven't received an update notification, go to Help -> Search for Flash Builder Updates)
          -Anirudh
          • 2. Re: Unable To Include Files In iOS Package
            leejk Level 1
            No, it still fails after the update. Atached is a screen shot of the
            error.
            Using the new AIR 2.7 SDK, I can compile this project from the command
            line with no issues. Flash Builder though seems to have all kinds of
            issues with this project I believe because of the number of files in this
            project. It has about 10,000 files in it.
            The other problem I see is that when modifying the project properties, FB
            will hang up, also I think from the number of files in this project.
            Please let me know if you have any suggestions.
            thx
            • 3. Re: Unable To Include Files In iOS Package
              Here is the bug: https://bugs.adobe.com/jira/browse/FB-31616
              The comments seem to indicate that if you put your files in a subfolder rather than directly in src, it should work.
              Let us know how it goes.
              -Anirudh
              • 4. Re: Unable To Include Files In iOS Package
                leejk Level 1
                Hello,
                Since I first encountered this bug, I have always had my asset files in
                subfolders. See the attached screen shot. This is my project folder, and
                every subfolder is included except for the com folder, which for some
                reason FB copied into the bin directory on it's own.
                So I do not think this fixed. In this report, they are not using the same
                number of files as I am, so it is possible that this only works with a low
                number of files.
                thx
                Anirudh Sasikumar <forums@adobe.com>
                06/23/2011 01:26 AM
                Please respond to
                clearspace-894750657-6285-2-3757081@mail.forums.adobe.com
                To
                Keith Lee <Lee_J_Keith@cat.com>
                cc
                Subject
                Caterpillar: Confidential Green Retain Until: 07/23/2011
                -Anirudh
                • 5. Re: Unable To Include Files In iOS Package
                  leejk Level 1
                  And here is the full stack trace error. It does not appear to be memory related. Any suggestions or is this a bug that will be fixed soon in an update?
                  java.lang.Exception
                  at com.adobe.flexbuilder.project.internal.FlexProjectCore.createErrorStatus(FlexProjectCore. java:1010)
                  at com.adobe.flexbuilder.util.logging.GlobalLogImpl.log(GlobalLogImpl.java:66)
                  at com.adobe.flexbuilder.util.logging.GlobalLog.log(GlobalLog.java:52)
                  at com.adobe.flexide.multiplatform.ios.packaging.IPAPackager.create(IPAPackager.java:220)
                  at com.adobe.flexide.multiplatform.ios.launching.IOSOnDeviceLaunchHandler.doPackage(IOSOnDev iceLaunchHandler.java:283)
                  at com.adobe.flexide.multiplatform.ios.launching.IOSOnDeviceLaunchHandler.launch(IOSOnDevice LaunchHandler.java:181)
                  at com.adobe.flexide.launching.multiplatform.MultiPlatformLaunchDelegate.launch(MultiPlatfor mLaunchDelegate.java:180)
                  at com.adobe.flexide.launching.AbstractFlexLaunchDelegate.launch(AbstractFlexLaunchDelegate. java:238)
                  at com.adobe.flexide.launching.AbstractFlexLaunchDelegate.launch(AbstractFlexLaunchDelegate. java:132)
                  at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:853)
                  at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:702)
                  at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:923)
                  at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1126)
                  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
                  • 6. Re: Unable To Include Files In iOS Package
                    We're investigating this and will get back to you on this.
                    -Anirudh
                    • 7. Re: Unable To Include Files In iOS Package
                      leejk Level 1
                      Hello, has anything been discovered about this problem?
                      thx
