7 Replies Latest reply on Sep 26, 2011 11:54 AM by AIF Bob
    crash occurs when division in material kernel
    Jin-Huang Champion
      Error: Error #3625: AGAL validation failed: Bad AGAL source operands. Both are constants (this must be precomputed) at token 24 of fragment program.
      The code scrap that causes the crash is as follows
      interpolated float4 d;
      d.x = //a float
      float density = .05;
      float f = exp( - density * density /  d.x / d.x);
      if it is"float f = exp( - d.x * d.x * density * density);", the app will be all right.
      Pls help me! Or my shader will become an opposite one...
      What's more, I find that interpolated variables in material kernel must be float4, otherwise it will crash in the runtime. Is it true? It's not written in the reference.
        • 1. Re: crash occurs when division in material kernel
          aifBharani Newcomer
          Thanks for posting ypur questions.
          --With regards to the AGAL validation error, its not valid to use two constant operands in a single instruction. Please copy over one of the constants to a temporary and use it for now. We ll fix it on our side to make this automatic under the covers if ppl use it in the language.
          --Also, I am not sure if its an AGAL restriction that interpolateds must be float-4. But, please use float-4 for now. If its an AGAL restriction, the language would still allow you to use float3s, but we ll take care of putting it into the right format while translating to AGAL.
          • 2. Re: crash occurs when division in material kernel
            tcorbet
            To Mr. Bharani with apologies to Mr. Jin-Huang,
            I am not attempting to hijack this thread; I am trying to understand it and turn it from a "Possibly Answered" one to a "Correctly Answered" one.
            I have spent ten hours trying to do something about:
            Error: Error #3625: AGAL validation failed: Bad AGAL source operands. Both are constants (this must be precomputed) at token 9 of vertex program.
            and have made no headway.
            Now, admittedly, I am a complete newbie, and quite evidently Mssrs. Jin-Hunag and Bharani are not.  Since I am exposing my ignorance for what I believe will be the benefit of a few other folks who are unable to understand what is wrong, and unable to understand how to correct it, let's define where I am.
            01.  I am trying to run what should be the simplest example from Mr. Santander's  minimole project. --  Segments Demo.  I think it is the simplest in terms of the amount of infrastructure required to make it work, and am I talking about the infrastructure both in the Actionscript API from the latest incubator download that is available [051211], as well as the infrastructure of the latest pixelbender3d toolkit [042711].
            02.  Now, unfortunately, that leaves us a little unsure as to whether or not minimole examples will work under those conditions.  Mr. Santander left us with some beautifully working examples at the end of April, but then announced that he was not going to be able to devote time to maintaining those sources.  The main reason, therefore, for my using this as the 'Hello World' example is that:
                a.  Adobe Labs does not provide a 'Hello World" example; and
                b.  At the end of June, Mr. Santander completed the migration of his project from SVN to GIT AND made a minor bug fix to his library.  Preseumably, his examples are working as of that date.
            So, that's the state of affairs -- I am sure that advanced users of these tools could get the Segments Demo running in a couple of minutes, but this is a request for the rest of us.
            03.  Where is there a list documenting Error Code #3625?  It is not to be found in the 051211 PRERELEASE DOCUMENTATION asdocs..
            04.  Given the three-way split of output from the compilation of two source files -- a vertexKernel.pbvk and a materialKernel.pbmk -- all of which have been black-box-welded by the time that this error occurs, in which source file should I look for "token 9"?
                at flash.display3D::Program3D/upload()
                at com.li.minimole.materials::MaterialBase/initPB3D()[G:\Flash_AS\lib\com\li\minimole\materi als\MaterialBase.as:85]
                at com.li.minimole.materials::LineMaterial/buildProgram3d()[G:\Flash_AS\lib\com\li\minimole\ materials\LineMaterial.as:46]
                at com.li.minimole.materials::MaterialBase/set context3d()[G:\Flash_AS\lib\com\li\minimole\materials\MaterialBase.as:45]
                at com.li.minimole.core::Mesh/set context3d()[G:\Flash_AS\lib\com\li\minimole\core\Mesh.as:109]
                at com.li.minimole.core::Scene3D/set context3d()[G:\Flash_AS\lib\com\li\minimole\core\Scene3D.as:31]
                at com.li.minimole.core::View3D/context3dCreatedHandler()[G:\Flash_AS\lib\com\li\minimole\co re\View3D.as:87]
            05.  Or, since Mr. Santander obviously spent a lot of time looking at these kinds of errors, in which of the three .pbasm files should I look for "token 9"?  Is it to be found anywhere in this diagnostic output?
            PB3D Version - major: 0, minor: 2
            - AgalProgramPair -
              vertexProgram:
                - AgalProgram -
                  temp. register count: 4
                  byteCode:   ¡    ää     ä ä     ä ä     ä ä      ää      ä ä      ä ä      ä ä      ª              ä ä      ä  ä
                U      U  ä      ä  ä
                U      U  ä     ä     U      U  ª      ª  U      ª  U      ª          ª      U  ÿ        U      U        ÿ       ª     U     ÿ     U      ä  ä
                U      U  ä      ä      ä       ä     U          ä         U  U   ä         ª  ª   ä       ä    ä
                  registers:
                    - RegisterMap -
                      numericalConstants:
                      - NumericalConstantsInfo -
                        startRegister: 0
                        values:
                      vertexRegisters: 3
                      - VertexRegisterInfo -
                        globalId:
                          - GlobalID -
                            format: float4
                            semantics: PB3D_OFF_DIRECTION
                        mapIndex: 0
                        globalId:
                          - GlobalID -
                            format: float4
                            semantics: PB3D_OP_POSITION
                        mapIndex: 1
                        globalId:
                          - GlobalID -
                            format: float4
                            semantics: PB3D_POSITION
                        mapIndex: 2
                      parameterRegisters: 3
                      - ParameterRegisterInfo -
                        globalId:
                          - GlobalID -
                            format: float_4X4
                            semantics: null
                        elementGroup:
                          - RegisterElementGroup -
                            contiguous: true
                            nElements: 16
                            elements:
                              - RegisterElement -
                                elementIndex: 0
                                registerIndex: 0
                                isValid: true
                              - RegisterElement -
                                elementIndex: 1
                                registerIndex: 0
                                isValid: true
                              - RegisterElement -
                                elementIndex: 2
                                registerIndex: 0
                                isValid: true
                              - RegisterElement -
                                elementIndex: 3
                                registerIndex: 0
                                isValid: true
                              - RegisterElement -
                                elementIndex: 0
                                registerIndex: 1
                                isValid: true
                              - RegisterElement -
                                elementIndex: 1
                                registerIndex: 1
                                isValid: true
                              - RegisterElement -
                                elementIndex: 2
                                registerIndex: 1
                                isValid: true
                              - RegisterElement -
                                elementIndex: 3
                                registerIndex: 1
                                isValid: true
                              - RegisterElement -
                                elementIndex: 0
                                registerIndex: 2
                                isValid: true
                              - RegisterElement -
                                elementIndex: 1
                                registerIndex: 2
                                isValid: true
                              - RegisterElement -
                                elementIndex: 2
                                registerIndex: 2
                                isValid: true
                              - RegisterElement -
                                elementIndex: 3
                                registerIndex: 2
                                isValid: true
                              - RegisterElement -
                                elementIndex: 0
                                registerIndex: 3
                                isValid: true
                              - RegisterElement -
                                elementIndex: 1
                                registerIndex: 3
                                isValid: true
                              - RegisterElement -
                                elementIndex: 2
                                registerIndex: 3
                                isValid: true
                              - RegisterElement -
                                elementIndex: 3
                                registerIndex: 3
                                isValid: true
                        globalId:
                          - GlobalID -
                            format: float4
                            semantics: null
                        elementGroup:
                            contiguous: true
                            nElements: 4
                            elements:
                              - RegisterElement -
                                elementIndex: 0
                                registerIndex: 4
                                isValid: true
                              - RegisterElement -
                                elementIndex: 1
                                registerIndex: 4
                                isValid: true
                              - RegisterElement -
                                elementIndex: 2
                                registerIndex: 4
                                isValid: true
                              - RegisterElement -
                                elementIndex: 3
                                registerIndex: 4
                                isValid: true
                        globalId:
                          - GlobalID -
                            format: float4
                            semantics: null
                        elementGroup:
                            contiguous: true
                            nElements: 4
                            elements:
                              - RegisterElement -
                                elementIndex: 0
                                registerIndex: 5
                                isValid: true
                              - RegisterElement -
                                elementIndex: 1
                                registerIndex: 5
                                isValid: true
                              - RegisterElement -
                                elementIndex: 2
                                registerIndex: 5
                                isValid: true
                              - RegisterElement -
                                elementIndex: 3
                                registerIndex: 5
                                isValid: true
                      textureRegisters: 0
              fragmentProgram:
                - AgalProgram -
                  temp. register count: 0
                  byteCode:   ¡   ä
                  registers:
                    - RegisterMap -
                      numericalConstants:
                        startRegister: 0
                        values:
                      vertexRegisters: 0
                      parameterRegisters: 1
                        globalId:
                          - GlobalID -
                            format: float4
                            semantics: null
                        elementGroup:
                            contiguous: true
                            nElements: 4
                            elements:
                              - RegisterElement -
                                elementIndex: 0
                                registerIndex: 0
                                isValid: true
                              - RegisterElement -
                                elementIndex: 1
                                registerIndex: 0
                                isValid: true
                              - RegisterElement -
                                elementIndex: 2
                                registerIndex: 0
                                isValid: true
                              - RegisterElement -
                                elementIndex: 3
                                registerIndex: 0
                                isValid: true
                      textureRegisters: 0
            Is there any helpful guide to understanding that diagnostic output?
            06.  Assuming that that message is pointing somewhere in here, where, exactly, and how, exactly, are we to write the code so is to avoid the compilers coming up with some operator that has two operands which are constants?
            module_vertex_program LineVertexKernel
                metadata
                    namespace const(string, "com.li.minimole")
                    vendor const(string, "Li")
                    version const(int, 1)
                    description const(string, "Projects vertices from object space to clip/screen space with an offset for line rendering.")
                end_metadata
                transformations
                    SCF INTOSSA OPT(DCE* {APR DCE*}*)
                end_transformations
                globals
                    global parameter float-4-4 objectToClipSpaceTransform
                    global parameter float-4 props
                    input vertex float-4 offsetDirection
                        metadata
                            id const(string, "PB3D_OFF_DIRECTION")
                        end_metadata
                    input vertex float-4 oppositeVertexPosition
                        metadata
                            id const(string, "PB3D_OP_POSITION")
                        end_metadata
                    input vertex float-4 vertexPosition
                        metadata
                            id const(string, "PB3D_POSITION")
                        end_metadata
                    output clipcoord float-4 vertexClipPosition
                end_globals
                functions
                    external_function void evaluateVertex()
                        body
                            basic_block entry%A !! outlets(basic%A)
                                position-0 = allocNonSSA type(float-4) : float-4
                                opPosition-0 = allocNonSSA type(float-4) : float-4
                                thickness-0 = allocNonSSA type(float) : float
                                L-0 = allocNonSSA type(float-4) : float-4
                                D-0 = allocNonSSA type(float-4) : float-4
                                P-0 = allocNonSSA type(float-4) : float-4
                                jump block(basic%A) : void
                            end_basic_block
                            basic_block basic%A !! inlets(entry%A) outlets(exit%A)
                                _LD_position-1 = mul vertexPosition, objectToClipSpaceTransform : float-4
                                _LD_opPosition-1 = mul oppositeVertexPosition, objectToClipSpaceTransform : float-4
                                propsElem%A-0 = extractVE props, const(int, 0) : float
                                propsElem%B-0 = extractVE props, const(int, 2) : float
                                _LD_thickness-1 = div propsElem%A-0, propsElem%B-0 : float
                                _LD_L-1 = sub _LD_opPosition-1, _LD_position-1 : float-4
                                _LD_L-2 = normalize _LD_L-1 : float-4
                                _LD_D-1 = normalize _LD_opPosition-1 : float-4
                                propsElem%C-0 = extractVE props, const(int, 1) : float
                                _LD_D-2 = insertVE propsElem%C-0, _LD_D-1, const(int, 3) : float-4
                                _LD_LElem%A-0 = extractVE _LD_L-2, const(int, 1) : float
                                _LD_DElem%A-0 = extractVE _LD_D-2, const(int, 2) : float
                                _mulResult%C-0 = mul _LD_LElem%A-0, _LD_DElem%A-0 : float
                                _LD_LElem%B-0 = extractVE _LD_L-2, const(int, 2) : float
                                _LD_DElem%B-0 = extractVE _LD_D-2, const(int, 1) : float
                                _mulResult%D-0 = mul _LD_LElem%B-0, _LD_DElem%B-0 : float
                                _subResult%B-0 = sub _mulResult%C-0, _mulResult%D-0 : float
                                _LD_LElem%C-0 = extractVE _LD_L-2, const(int, 2) : float
                                _LD_DElem%C-0 = extractVE _LD_D-2, const(int, 0) : float
                                _mulResult%E-0 = mul _LD_LElem%C-0, _LD_DElem%C-0 : float
                                _LD_LElem%D-0 = extractVE _LD_L-2, const(int, 0) : float
                                _LD_DElem%D-0 = extractVE _LD_D-2, const(int, 2) : float
                                _mulResult%F-0 = mul _LD_LElem%D-0, _LD_DElem%D-0 : float
                                _subResult%C-0 = sub _mulResult%E-0, _mulResult%F-0 : float
                                _LD_LElem%E-0 = extractVE _LD_L-2, const(int, 0) : float
                                _LD_DElem%E-0 = extractVE _LD_D-2, const(int, 1) : float
                                _mulResult%G-0 = mul _LD_LElem%E-0, _LD_DElem%E-0 : float
                                _LD_LElem%F-0 = extractVE _LD_L-2, const(int, 1) : float
                                _LD_DElem%F-0 = extractVE _LD_D-2, const(int, 0) : float
                                _mulResult%H-0 = mul _LD_LElem%F-0, _LD_DElem%F-0 : float
                                _subResult%D-0 = sub _mulResult%G-0, _mulResult%H-0 : float
                                propsElem%D-0 = extractVE props, const(int, 1) : float
                                _LD_P-1 = makeFloatVector _subResult%B-0, _subResult%C-0, _subResult%D-0, propsElem%D-0 : float-4
                                _LD_P-2 = normalize _LD_P-1 : float-4
                                offsetDirectionElem%A-0 = extractVE offsetDirection, const(int, 0) : float
                                _mulResult%I-0 = mul _LD_P-2, offsetDirectionElem%A-0 : float-4
                                _LD_P-3 = mul _mulResult%I-0, _LD_thickness-1 : float-4
                                propsElem%E-0 = extractVE props, const(int, 1) : float
                                _LD_P-4 = insertVE propsElem%E-0, _LD_P-3, const(int, 3) : float-4
                                _LD_positionElem%A-0 = extractVE _LD_position-1, const(int, 0) : float
                                _LD_PElem%A-0 = extractVE _LD_P-4, const(int, 0) : float
                                _addResult%A-0 = add _LD_positionElem%A-0, _LD_PElem%A-0 : float
                                _LD_position-2 = insertVE _addResult%A-0, _LD_position-1, const(int, 0) : float-4
                                _LD_positionElem%B-0 = extractVE _LD_position-2, const(int, 1) : float
                                _LD_PElem%B-0 = extractVE _LD_P-4, const(int, 1) : float
                                _addResult%B-0 = add _LD_positionElem%B-0, _LD_PElem%B-0 : float
                                _LD_position-3 = insertVE _addResult%B-0, _LD_position-2, const(int, 1) : float-4
                                _LD_positionElem%C-0 = extractVE _LD_position-3, const(int, 2) : float
                                _LD_PElem%C-0 = extractVE _LD_P-4, const(int, 2) : float
                                _addResult%C-0 = add _LD_positionElem%C-0, _LD_PElem%C-0 : float
                                _LD_vertexClipPosition-1 = insertVE _addResult%C-0, _LD_position-3, const(int, 2) : float-4
                                jump block(exit%A) : void
                            end_basic_block
                            basic_block exit%A !! inlets(basic%A)
                                moveToNonSSA _LD_vertexClipPosition-1, vertexClipPosition : void
                                ret : void
                            end_basic_block
                        end_body
                    end_external_function
                end_functions
            end_module_vertex_program
            I hope I have found the right "stuff" and correctly laid out what I think is the 'pipeline", so that you can reply with some nice, clear, interspersed comments using big, bold, red text to help us learn how to use these tools.
            Thank you.
            • 3. Re: crash occurs when division in material kernel
              AIF Bob Pioneer
              This error:
              is caused by doing a computation with two values that are parameters. Take this kernel for example:
              <languageVersion : 1.0;>
              vertex kernel Bulge
                  namespace : "AIF Test";
                  vendor : "Adobe";
                  version : 1;
                  parameter float scale;
                  parameter float scale2;
                  parameter float4x4 objectToClipSpaceTransform;
                  input vertex float4 vertexPosition
                  input vertex float4 vertexNormal;
                  output vertex float4 vertexClipPosition;
                      float4 t = vertexPosition;
                      t += vertexNormal * ( scale + scale2);
                      vertexClipPosition = t * objectToClipSpaceTransform;
              Because scale and scale2 are both parameters (and therefore constant for every vertex), the value scale + scale2 isn't going to change and could actually be precomputed. The low level hardware doesn't allow you to do a computation with two parameters like this. We are fixing the compiler to allow this (although it's still not a great idea - it puts in extra instructions that aren't necessary and will slow down the computation). In the meantime, there are two workarounds:
              1. Do the computation outside the kernel. In the example shown oprecalculate scale + scale2 and pass in the result of that computation as the parameter.
              2. Copy one of the values to a temporary and use the temporary in the computation:
                      float temp = scale2;
                      t += vertexNormal * ( scale + temp);
              Bob
              • 4. Re: crash occurs when division in material kernel
                tcorbet Newcomer
                Bob,
                Thank you for a clearer statement of the problem.
                I also understand and appreciate the fact that performing some operation on two constants on the 'Actionscript side of the interface' will result in a more efficient pipeline.
                So, part of my objective has been met.  For the benefit of the community I wonder if I can entice you to going the second mile?  I understand the roles played by the various members of a software development organization, so I am pretty sure that you don't get up every day looking for a chance to do quality assurance on the technical writing team.  Can we be assured that as an 'Employee' moinitoring and providing helpful assistance for the forum, as you have here, that the issues being raised are finding their way back to product management for the allocation of the necessary resources?
                You have ignored the question/quandry that the user has in attempting to get from the cryptic diagnostic error message to where s/he can fix the problem.
                A.  Where is the cross-reference of error codes to nice descriptions of their meaning?
                B.  How would the user know whether to look for the problem in the vertex kernel or the material kernel source?
                C. You know that a parameter data type is a constant, but how does the new user come to learn that?
                D.  What is the heuristic for getting from a Token # to a line of code?
                My hope is that working on these matters will result in a better product for Adobe and for those of us who imagine using your facilities to deliver superior rich application experiences.
                • 5. Re: crash occurs when division in material kernel
                  AIF Bob Pioneer
                  function(){return A.apply(null,[this].concat($A(arguments)))}
                  I can certainly give you that assurance. We're a small team, and most of the Adobe people responsing to posts on this forum are part of that small team. We do feed the information on here back to our management, and we do take it into account when planning.
                  Pixel Bender 3D is built on top of the Molehill API that is part of Flash. That's handled by a separate team. There's a bunch of information on the Molehill APIs here:
                  http://labs.adobe.com/technologies/flashplatformruntimes/incubator/features/molehill.html
                  I had a quick look and couldn't find a listing of error codes.
                  Our goal with the Pixel Bender 3D components is never to hand anything in to Molehill that will give errors. We are obviously not there yet but we're working on it.
                  Once we have all of the error checking into the compiler stages properly, the compiler will tell you. If there is a problem in the Molehill API you'll probably need to swap out a vertex program for a known good vertex program and see if that fixes the problem. Relating that back to the original source code can be tricky though, the compiler does a lot of optimization work which means that the final output is often very different from the source input.
                  Through what will be improved documentation by the time we ship, through better error checking in the compiler so that error messages relate more closely to the original source code and through discussions like this on the forum.
                  There isn't one I'm afraid. It's like trying to get from a line of assembler to the original line of C++ or Java or ActionScript.
                  The bottom line is that we know that what we're shipping now isn't production quality - it's a beta release. We're taking the feedback we get to fix bugs, improve the documentation and make the system more robust so that when we do the full release we'll be putting out a much higher quality system.
                  I know that it's frustrating working with prerelease software and documentation, but this is exactly the sort of feedback we need to improve things.
                  Thanks for your questions.
                  Bob
                  • 6. Re: crash occurs when division in material kernel
                    karendanes
                    Hi Jin,
                    Can  you please upload the kernel you're trying to put through the compiler and the command line you were using and i will try to look into it.
                    __________________________________
                    Add url free or submit your articles
                    • 7. Re: crash occurs when division in material kernel
                      AIF Bob Pioneer
                      This problem has been fixed in preview 3 of Pixel Bender 3D
                      Bob
