8 Replies Latest reply on Jun 15, 2011 11:34 AM by Adam Cameron.
    onSessionEnd not working as expected
      I have read many posts by people who have problems with onSessionEnd.  This is my first conversion of application.cfm to application.cfc and the onSessionEnd is not working with the CFFunction I am trying to invoke.
      I guess what's hanging this up is how to properly call the component from the /lib/components/ folder where it resides.
      When a user logs in I am creating a session array that tracks a jobNumber and the last_completed_step in that job.  There are multiple jobs in a users session.  At the end of the session I want to write the updated array data back to the DB.
      I should make it clear that at present I look into my log file and see that the session is started - as coded in the onSessionStart shown below.  Furthermore, the onSessionEnd also writes to the log file when I take out the invocation of the component.  In other words if I just tell it to write "Session ended." to the log file I will see it in the log file. I have set current session timeout in CF Administrator and my app.cfc for 3 minutes for testing.
      If I call the "giveMeAnswer" method in the jobState.cfc from a separate file (also at the root level) the giveMeAnswer method works properly and returns the value "I am a CFC."
      If I move the jobState.cfc to the root level and set the component attribute to "jobState" I am also getting a return from the component.
      <!--- Runs when your session starts --->
      <cffunction name="onSessionStart" returnType="void" output="false">
          <!--- :: invoke all session variables | moved out of on session start  :: --->
          <cfinvoke component="#application.virtualPaths.cfcPath#system/sessionVars" method="init" />
          <cflog file="#This.Name#" type="Information" text="Session started.">
      <!--- Runs when session times out --->
      <cffunction name="onSessionEnd" returntype="void">
          <cfargument name="SessionScope" type="struct" required="true" />
          <cfargument name="ApplicationScope" type="struct" required="true" />
          <cfinvoke component="/lib/components/jobState" method="giveMeAnswer" returnvariable="returnFromCfc">
          <cflog file="#This.Name#" type="Information" text="Session ended.  #returnFromCfc#">
          <cfreturn />
      So, is it just not finding the component?  Any other ideas?
      Thanks much, Jerry
