3 Replies Latest reply on Jun 15, 2011 1:38 PM by RenéG
    Required amount of digits in a field
    RenéG Level 3
      I have a Form, done with Acrobat Pro 8 and there is one field that people need to enter their 9 digits account number.
      We want to set-up the pdf so that if they enter, let's say, 8 digits, they'll get a message that 9 digits is required.
      How do I do that?
      Be kind of specific as I'm not very advanced in that scripting thing. I know a bit but not much.
      Thanks!
        • 1. Re: Required amount of digits in a field
          George_Johnson MVP & Adobe Community Professional
          You can use a custom Validate script for this. This script would check to see if it's not blank, and if so, if there are nine characters. SOmething like:
          // Custom Validate script for text field
          (function () {
              // Get the field value
              var val = event.value;
              // Do nothing if the field is blank
              if (!val) return;
              // Make sure there are 9 characters
              if (val.length !== 9) {
                  // Alert the user
                  app.alert("Your message goes here.", 3);
                  // Optionally, reject the value
                  event.rc = false;
          • 2. Re: Required amount of digits in a field
            RenéG Level 3
            Thanks George.
            Only one thing is that it deletes the numbers the customer already keyed in, if he enters let's say 8 digits.
            Is it possible that it leaves his entry as is? Or would that be too complicated of script?
            • 3. Re: Required amount of digits in a field
              RenéG Level 3
              Oops, never mind, I deleted that optional line you put in there.
              Answer this post and I'll give you full credit for the right answer.
