5 Replies Latest reply on Jun 17, 2011 1:38 AM by Emmanuel Brochard
    Accessing errors in Indesign
    xmlapi Level 1
      How do I access the "errors panel" in Indesign (the one that shows missing fonts, overset text etc) using javascript?
        • 1. Re: Accessing errors in Indesign
          John Hawkinson Level 5
          Do you mean Live Preflight?
          • 2. Re: Accessing errors in Indesign
            csm_phil Level 4
            Can you please try this below line:
            app.scriptPreferences.userInteractionLevel=UserInteractionLevels.interactWithAll;
            thx
            csm_phil
            • 3. Re: Accessing errors in Indesign
              Emmanuel Brochard
              I don't know if it is what you meant but you can inspire from this following example to manipulate preflight from JS :
              try{
                  // Basic
                  var preflightProfile = app.preflightProfiles.firstItem();
                  // Execution
                  $.writeln("Execution <" + preflightProfile.name + ">");
                  var preflightProcess = app.preflightProcesses.add(app.activeDocument, preflightProfile);
                  var preflightReturn = preflightProcess.waitForProcess();
                  preflightResults = preflightProcess.processResults;
                  $.writeln("Return value <" + preflightReturn + ">");
                  $.writeln("Return value <" + preflightResults + ">");
                  // Results
                  if (preflightResults != 'None'){
                      $.writeln("Preflight : " + preflightProcess.aggregatedResults[2].length + " error(s) ");
                      for (var i = 0 ; i < preflightProcess.aggregatedResults[2].length ; i++){
                          var preflightError = preflightProcess.aggregatedResults[2][i] ;
                          $.writeln("\n" + i + ".ERR   - " + preflightError[1] +
                                            "\n" + i + ".PAGE - " + preflightError[2] +
                                            "\n" + i + ".INFO - " + preflightError[3]
                 // PDF
                 preflightProcess.saveReport(File(yourDir + "/" + "preflight.pdf"), true);
                 // Cleanup
                 preflightProcess.remove();
              } catch (ex) {
                 // Exception
              Manu
              • 4. Re: Accessing errors in Indesign
                xmlapi Level 1
                Thanks, Is it possible to get the actual text frame that was overset USING preflight?
                • 5. Re: Accessing errors in Indesign
                  Emmanuel Brochard Level 1
                  I do not know. The preflight gives the page with an error. Perhaps, just browse the textframes of the page to detect that which is in overflow.
                  Manu
